EWaptBadSignature
guigeek
Registration: Nov 21, 2017 - 9:21 p.m.
May 11, 2022 - 5:12 PM
Since reinstalling the console, I've been getting this error when changing the maturity level of a package, for example:
ERROR;EWaptBadSignature: Check_package_signature failed
Any idea where this could be coming from?
Thanks in advance,
Guillaume
PS: Wapt server 2.2
May 11, 2022 - 5:43 PM
The old package signature doesn't seem to be recognized.
Have you not regenerated a key?
guigeek
May 12, 2022 - 08:21
I admit that many things have been tested.
But I have another PC with the console that works perfectly;
is it possible to copy everything (keys? certificates?) so that the problem disappears?
guigeek
May 18, 2022 - 4:52 PM
Any ideas?
May 18, 2022 - 5:00 PM
Generally, you need to be careful not to create too many keys because it's easy to get lost in them.
Then, to re-sign in "C:\Program Files (x86)\wapt\ssl", your machine with the console needs to know all the old keys.
Is that the case?
