Issue using WinPE Usb Key\Bootsect.exe
juniormateus
Registration: May 5, 2022 - 4:53 p.m.
May 11, 2022 - 4:18 PM
juniormateus wrote: May 11, 2022 - 4:08 PM
juniormateus wrote: May 11, 2022 - 4:01 PM
sfonteneau wrote: May 11, 2022 - 1:51 p.m. I just updated the tis-wads-requirement-minimal package
https://luti.tranquil.it/get_folder_res ... 93aW5kb3dz
it now includes the copy of the Bootsect.exe file if it is not present on your machine
you can duplicate the package from this repository: https://wapt.tranquil.it/wapt-testing/
Thank You let me tested, and I will let you know
I got this error, when try to duplicate
http://snpy.in/3Qlvvk
I think maybe because the machine, where i running the package are a windows server 2019, i will try on a windows 10 machine
May 11, 2022 - 4:56 PM
Yes try and get back to me
I don't see any 404 on a wads package on the store here
Apparently it's not our server returning a 404.
juniormateus
May 12, 2022 - 12:46
Hi i have one question, for better preparing the OS Boot via TFTP or Pen drive
Is it a requirement that the WAPT Console Management being installing on a Windows 10 machine?
Can i use a windows 2019 server? for Console Management?
Because i receive another error on the windows 10
here is the print screen link: http://snpy.in/Fnn3d2
May 12, 2022 - 12:54
Everything should work fine also on a Windows 2019 server
Can you close the console
Delete folder %tmp%\winpe
And try again to create the winpe?
WARNING: the machine that generates winpe from the console must have the tis-wads-requirement-minimal package installed
juniormateus
May 12, 2022 - 3:44 PM
sfonteneau wrote: May 12, 2022 - 12:54 Everything should work fine also on a Windows 2019 server
I still receive this error, when trying to download the new package
link: http://snpy.in/6J9jjU
May 13, 2022 - 09:54
But the file is there...
https://wapt.tranquil.it/wapt-testing/t ... f7d66.wapt
You can download here and import as a file
May 13, 2022 - 3:08 PM
Hi juniormateus
juniormateus wrote: May 12, 2022 - 3:44 p.m.
I still receive this error, when try to download the new package
Please try to refrain to use url shortener on forum, one never now where it will take him... :-)
Thanks,
June 13, 2022 - 3:27 PM
Did you manage to download the file?
https://wapt.tranquil.it/wapt-testing/t...f7d66.wapt
