Hi ,
I have create a self service, but i can't deployed it
here is the print screen:
Auditing Infra_Rep02
OK: No setup.py
Package EB5DA14D-39A8-E911-8102-F8B46A195AFA(=3) is not installed
File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1880, in run
self.running_task.run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 662, in run
self._run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1321, in _run
self.result.append('%s: %s' % (package, self.wapt.audit(package, force=self.force, audited_by=self.created_by)))
File "C:\Program Files (x86)\wapt\common.py", line 6920, in audit
raise Exception('Package %s is not installed' % package)
Exception: Package EB5DA14D-39A8-E911-8102-F8B46A195AFA(=3) is not installed
self._run()
can't deploy self service
- WAPT Expert
Hello
The machine package is in error
You have to click on the machine then on the package in error on the right panel to understand why it is in error
