I'm sorry to bother you, this is becoming a bad habit
I am currently finalizing my various tests for importing an "existing" machine onto a WAPT 2.2 enterprise system
I put back my usual batch of packages
Everything behaves "normally" except for Teams
Older Microsoft Teams version found (1.4.0.22976)
Removing: Teams Machine-Wide Installer (1.4.0.22976)
Installing: Teams_windows_1.5.0.9163_x64.msi
File "C:\Program Files (x86)\wapt\common.py", line 4035, in install_wapt
File "C:\WINDOWS\TEMP\wapthk53itws\setup.py", line 49, in install
File "C:\Program Files (x86)\wapt\common.py", line 3990, in new_func
return func(*args, **kwargs)
File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 1501, in install_msi_if_needed
run(r'msiexec /norestart /q /i "%s" %s' % (msi, props), accept_returncodes=accept_returncodes, timeout=timeout, pidlist=pidlist)
File "C:\Program Files (x86)\wapt\waptutils.py", line 2123, in run
waptutils.CalledProcessErrorOutput: Command 'msiexec /norestart /q /i "Teams_windows_1.5.0.9163_x64.msi" OPTIONS="noAutoStart=true" ALLUSER=1' returned non-zero exit status 1638.
Output:U n e a u t r e v e r s i o n d e c e p r o d u i t e s t d Ú j Ó i n s t a l l Ú e . I m p o s s i b l e d e p o u r s u i v r e l i n s t a l l a t i o n d e c e t t e v e r s i o n . P o u r c o n f i g u r e r o u s u p p r i m e r l a v e r s i o n e x i s t a n t e d e c e p r o d u i t , u t i l i s e z l a p p l i c a t i o n A j o u t / S u p p r e s s i o n d e p r o g r a m m e s d u P a n n e a u d e c o n f i g u r a t i o n .
Thanks in advance
