Waptdeploy and two domains?
knpc
Registration: Nov. 20, 2015 - 4:40 p.m.
April 13, 2016 - 6:17 PM
I deployed waptdeploy on one domain without any problems, but it won't work on the second.
When I run the command on a machine in the second domain (using DOS), it tries to find the Agent package on the wrong WAPT server.
The first domain is mont-tremblant.local,
and the web server is http://wapt.mont-tremblant.local/wapt (CORRECT).
The second domain is xxxxx.villedemont-tremblant.qc.ca, and
the web server it's looking for is http://wapt.xxx.villedemont-tremblant.qc.ca/wapt (INCREDIBLE),
whereas it should be pointing to the first one.
Why is this happening, and how can I fix it?
Thanks
, Knpc
April 14, 2016 - 1:28 AM
I assume the DNS suffix of the machine you're testing on is xxx.villedemont-tremblant.qc.ca/wapt.
So it makes sense; wapt deploy will look for the server at:
http://wapt.xxx.villedemont-tremblant.qc.ca/tagent.exe.
Here are all the possible options with waptdeploy:
https://github.com/tranquilit/WAPT/blob/es.pas#L22.
I think the --waptsetupurl option should help you,
Simon.
April 14, 2016 - 1:44 AM
The other solution would be to add the wapt DNS entry to your zone xxx.villedemont-tremblant.qc.ca
