[SOLVED] Nginx package error during installation
Patrice
Registration: February 18, 2015 - 3:22 PM
May 18, 2022 - 1:01 PM
I would like to make a number of servers secondary repositories. Therefore, to do this, I used the TIS-remote-repo-nginx package.
The package installed without error on some servers, but on others the service WAPTRepoNginx is paused. It cannot be started. When attempting to start it manually, Windows displays the following error:
Windows could not start the WAPTRepoNginx service on Local Computer.
The service did not return an error. This could be an internal Windows error or an internal service error.
The package is then in error indicating
"The service did not respond quickly enough to the request for launch or control."
Has anyone else encountered this problem and solved it? If so, how did you do it?
Thank you all for your help.
Patrice
WAPT Enterprise 2.2
Patrice
May 19, 2022 - 09:56
Problem solved.
My issue was that the servers in question already had port 80 open by the system.
WAPT Enterprise 2.2
May 23, 2022 - 12:33
Thanks Patrice for the feedback!
See you soon,
