when I add a driver configuration to a deployment, the deployment doesn't start.
The command "start x:\dlls\..." crashes and nothing happens.
However, the deployment starts when I don't add any driver configuration.
Do I need to add the drivers to the Windows 10 ISO?
Thank you.
[RESOLVED] WADS - Adding drivers
- WAPT Expert
Do you have any special characters in your driver bundle name (there was/was a bug there)? If you rename it, remember to reassign it to the machine you're deploying it to.
- WAPT Expert
Hi smandel,
I've created an internal ticket to use a GUID instead of the bundle name written by the sysadmin; this will avoid any future problems with special characters.
