I would like to cancel the installation, which is stuck because I made a mistake in the package.
I don't want to wait the 15-minute timeout but cancel it immediately.
Is there a command I need to run? Please note that I don't have a graphical interface on the client machines.
Cancel the current task
- WAPT Expert
Using wapttray.exe or the console you can use "cancel current task"
- WAPT Expert
I'm not sure this answer will suit you better, but I'll give it to you anyway:
From the client you can visit:
For the current task or:
For all tasks
But anyway, it's pretty much the same as the Wapttray
http://127.0.0.1:8088/cancel_running_task.jsonCode: Select all
http://127.0.0.1:8088/cancel_all_tasks.jsonBut anyway, it's pretty much the same as the Wapttray
