[SOLVED] Error: WINPE - tis-wads-requirement-minimal
Garangiss
Registration: June 2, 2022 - 4:25 PM
June 2, 2022 - 4:35 PM
Hello everyone,
I frequently use WAPT to deploy my software to about ten computers. Recently, I noticed the "Deploy an OS" feature. So I downloaded the "tis-wads-requirement-minimal" package and its dependencies. However, when I try to download WinPE, this error message appears:
This topic is identical to this one: viewtopic.php?t=2958 . But unfortunately, I haven't found a solution.
Thank you for your time,
Garangiss.
June 2, 2022 - 5:15 PM
Were you able to duplicate the package from our store to your warehouse?
Garangiss
June 3, 2022 - 08:49
Yes, indeed. I managed to download this package using the "Import a package" function. I also tried downloading it from your web interface store (with the dependency), but the problem persists.
On another virtual machine, I also tried installing the following packages: tis-adkwinpe and tis-microsoft-adk (because, based on their descriptions, they are packages that enable WinPE). But the problem still remains.
Regards,
Garangiss.
June 3, 2022 - 09:24
As the message says, did you "duplicate" and "install" it on your management workstation?
Garangiss
June 3, 2022 - 9:50 AM
No, I must be missing that step. Do you have any documentation or video on this?
Thanks again to "dcardon" and "sfonteneau" for the help,
Garangiss.
Garangiss
June 3, 2022 - 09:57
Update:
I just reinstalled the package in question, and this message appears. I therefore conclude that the duplication was successful. Is there anything else I need to do after this?
Update 2:
I signed the packages using the "Sign .exe files on the server" feature. But the error message is still present.
Regards,
Garangiss.
June 3, 2022 - 10:53
https://www.wapt.fr/fr/doc/ It's well explained there...
duplicated/imported -> it's in the local repository
installed -> it's on the machine.
Garangiss
June 3, 2022 - 1:36 PM
"Duplicated/imported -> it's in the local repository": Done, it appears in the local repository.
"Installed -> it's on the machine": I installed the package on the WAPT server using the "Download packages" feature in the "Private Repository" tab. This downloads the packages to the "AppData\Local\waptconsole\cache\global" folder. I still can't find a solution, despite reading the documentation and watching a few videos on the subject.
(Documentation: https://www.wapt.fr/fr/doc/wapt-wads-windows.html)
Garangiss
June 3, 2022 - 1:52 PM
Resolved, I didn't realize it had to be installed like deployable software. Thanks everyone, you can close this!
