Delete the binary file "Install_PRNclient_FR_2021.0.2.10_win64.exe".
Can you also test on a Windows 10 x64 PC?
[SOLVED] Edt Package v2022 build 0.3.0 / Pronote v2022 build 0.3.0
olaplanche
- Registration: January 26, 2017 - 11:11
- Installed WAPT version: 2.6.0.16795 Enterprise
- Server OS: Linux / Debian Bookworm
So I see, I delete the .exe file from waptdev and then update-package, is that right?
If so, I get this error during the update
Ligne de Commande : update-package-sources "c:\waptdev\gmwapt-client-pronote-2021-0210_0.2.10-1_x64_windows_PROD-wapt\WAPT\.."
Using config file: C:\Users\winadmin\AppData\Local\waptconsole\waptconsole.ini
Downloading/Updating package content from upstream binary sources
2022-06-09 13:33:16,528 CRITICAL Fatal error in update_package function: None : None:
File "C:\Program Files (x86)\wapt\waptpackage.py", line 2974, in call_setup_hook
hookdata = hook_func()
File "c:\waptdev\gmwapt-client-pronote-2021-0210_0.2.10-1_x64_windows_PROD-wapt\setup.py", line 119, in update_package
page = wgets(control.sources,proxies=proxies)
File "C:\Program Files (x86)\wapt\waptutils.py", line 1130, in wgets
r = session.get(url, timeout=timeout, allow_redirects=True)
File "C:\Program Files (x86)\wapt\Scripts\lib\site-packages\requests\sessions.py", line 555, in get
return self.request('GET', url, **kwargs)
File "C:\Program Files (x86)\wapt\Scripts\lib\site-packages\requests\sessions.py", line 528, in request
prep = self.prepare_request(req)
File "C:\Program Files (x86)\wapt\Scripts\lib\site-packages\requests\sessions.py", line 456, in prepare_request
p.prepare(
File "C:\Program Files (x86)\wapt\Scripts\lib\site-packages\requests\models.py", line 316, in prepare
self.prepare_url(url, params)
File "C:\Program Files (x86)\wapt\Scripts\lib\site-packages\requests\models.py", line 390, in prepare_url
raise MissingSchema(error)
requests.exceptions.MissingSchema: Invalid URL '': No schema supplied. Perhaps you meant http://?
FATAL ERROR : None : None
Exit code: 3
>>> - Installed WAPT version: 2.2.1.11949 Discovery
- Server OS: Linux / Debian 11
- Administration/package creation machine OS: Windows 7
olaplanche
Argh, I forgot to update the source URL on the first post!
The correct address is:
Pronote is really complicated to package.
I keep getting a series of errors when changing the source
I then use the update-package (I don't have the update-package sources)
and I'm still getting this series of errors
2022-06-09 13:44:43,438 CRITICAL Fatal error in update_package function: None : None:
p.prepare(
Exit code: 3
olaplanche
Ah, in my opinion there's a problem with the development PC.
Can you confirm the following points:
- Is the tis-waptdev package properly installed on the development machine?
- Is Pyscripter running as administrator?
Yes, waptdev is installed on my machine, which is the one I use to manage the wapt console and package deployment.
And yes, pyscripter is running as administrator.
- WAPT Expert
Hello SebAranel,
There are features that are only available in the Enterprise version, so to avoid misleading people regarding their answer, it is better to specify the edition (see your post footer).
Since version 2.2, the binary is the same for both the Discovery and Enterprise editions; only the presence of a license changes how it works. In your case, the number of licenses is -1, so no license is present.
Hello
, yes indeed, I was supposed to modify it, but I haven't had the chance.
Regarding the functionality, we agree that this only concerns the use of the console and not the deployment of packages to workstations?
Regards,
SebAranel
Regards,
SebAranel
