waptagent/waptdeploy /StartPackages does nothing
dsp
Registration: February 27, 2018 - 09:15
January 22, 2020 - 12:03
I'm not sure if I'm doing this correctly, but nothing happens when I use `/StartPackages=package_name` with Waptagent or `--setupargs=/StartPackages=package_name` with Waptdeploy.
However, modifying `set_start_packages` in Waptagent.iss before generating the Waptagent package works.
specific
group of packages directly during installation, depending on the machine being installed. Regards
WAPT version: 1.8.2
Server OS: Debian 10
Administration/package creation machine OS: Windows 10 1909
LMU-wapt
Registration: Oct 02, 2020 - 11:04
May 12, 2021 - 5:58 PM
I have the same problem in version 2.0 with the wapt agent and the /StartPackages=XXX parameter.
Is this parameter still functional?
Where can I find logs to try and find the source of the problem?
Thank you.
- Installed WAPT version (2.0)
- Server OS: Linux and Debian 10 version
May 18, 2021 - 3:27 PM
That should work. I'm opening an internal ticket to track this issue. Otherwise, you can create an OU package so the machine retrieves its updates after joining the domain.
Regards,
bsok
Registration: June 15, 2022 - 4:01 PM
June 16, 2022 - 09:25
the problem persists.
So it won't be fixed in community version 1.8.2?
Regards,
Bernard.
June 16, 2022 - 09:32
Hello bsok,
bsok wrote: ↑June 16, 2022 - 9:25 AM The malfunction persists.
Tranquil IT has stopped contributing to WAPT Community 1.8.2 support. But that doesn't prevent another user, or yourself, from fixing it and publishing their fix (the WAPT 1.8.2 Community code is under GPLv3).
