I'd like to create a Scratch 3 .exe package in WAPT, but I'm having trouble. I'm still new to WAPT.
I'm having a problem with the uninstallation key. When I install the software using its installer (without WAPT), I can retrieve the uninstallation key using the command "wapt-get list-registry".
However, once I create my new WAPT package and specify the uninstallation key, I can still install the package, but with the following error (in summary): "The uninstallation key was not found". And indeed, I can't find the uninstallation key using the "wapt-get list-registry" command... It's missing.
Therefore, when I try to uninstall (remove), the package seems to uninstall but remains installed on the machine...
Can you tell me what my mistake is or suggest a possible solution?
Thank you!
[SOLVED] Creating a Scratch 3 .exe package
there is an outdated package available on the store: https://wapt.tranquil.it/store/tis-scratch
I'm adding it to the list of packages to be managed by Luti: https://www.tranquil.it/luti-creation-t ... uets-wapt/
- WAPT Expert
The package is available for testing and should be available in the store soon.
https://wapt.tranquil.it/wapt-testing/t ... EPROD.wapt
Regards,
Regards,
stephane.lang
- Registration: June 14, 2022 - 11:54
Excellent, thank you!
Stéphane Lang
