HP Support Assistant Package
pierre.baridon
Registration: Nov 14, 2020 - 10:55
October 28, 2021 - 6:07 PM
has anyone here ever worked on a package to deploy "HP Support Assistant" (an update/support tool for HP workstations)?
I'm having some difficulty with the package. Installation with an administrator account is no problem, however, with the local system account at boot, some dependencies fail to install.
Thanks!
Pierre
- Installed WAPT version (2.1.0 Enterprise)
- Server OS: Debian
Eddy
Registration: February 3, 2022 - 12:07 AM
February 3, 2022 - 12:14 AM
Good evening,
could you share your script?
I'm not particularly familiar with Python.
After trying several scripts, an error occurs every time...
Thanks in advance
, Eddy
- WAPT version installed (2.2.3 Enterprise)
- Server OS: Debian
pierre.baridon
June 9, 2022 - 5:25 PM
Here is the first draft of my script:
import time
CommandVendor = 'wmic systemenclosure get manufacturer'
CommandModel = 'wmic COMPUTERSYSTEM get Model'
Vendor = str(run(CommandVendor))
Model = str(run(CommandModel))
    # Declaring local variables
    print ("Fabricant : ", Vendor)
    print ("Model : ", Model)
    if Vendor.find('HP') != -1 :
        print("Installation Prerequis")
        print("Installation de HP Support Assistant sur machine HP")
        # Installing the software
        print("Installing: %s" % control.package)
        #install_exe_if_needed('InstallHPSA.exe',
        #    silentflags='/S /v/qn',
        #    key='',
        #    min_version=control.get_software_version(),
        install_exe_if_needed('setup.exe',
            silentflags='-s',
            key='',
        print("Pas un materiel HP")
    print("désinstallation de HP Support Assistant")
    run ('"' + makepath(programfiles32,'HP','HP Support Framework','UninstallHPSA.exe') + r'" /S /v/qn')
- Server OS: Debian
florentR2
Registration: February 13, 2020 - 5:23 PM
June 10, 2022 - 09:39
I've noticed that HPIA doesn't necessarily require installation.
You can simply retrieve the folder from a PC where it's installed. I chose this solution and then set up a scheduled task that launches HPIA tasks via the command line.
pierre.baridon
June 22, 2022 - 5:03 PM
florentR2 wrote: June 10, 2022 - 9:39 AM Hello,
I noticed that HPIA doesn't necessarily require installation.
Do you have any documentation/examples for launching tasks via the CLI?
- Server OS: Debian
florentR2
June 22, 2022 - 5:08 PM
There's a CLI section in the documentation: https://ftp.hp.com/pub/caps-softpaq/cmi ... rGuide.pdf
