Package import
ricci
Registration: March 5, 2016 - 11:09
March 5, 2016 - 11:19
I'm currently learning WAPT and I'm encountering the following problem.
I created a new, updated virtual server.
I installed the WAPT server in a basic way to explore its capabilities.
When I try to import packages, I get the following error message:
An unhandled exception has occurred
HTTPError: 400 Client Error: Bad Request for url:
...://servername/upload_package/packagename.
I can't find a solution on my own;
the log folder only contains empty files.
Thank you for your help.
Alex
Registration: Apr 26, 2016 - 09:49
April 26, 2016 - 9:50 AM
does anyone have an answer to this error message because I'm getting the exact same one. I've tested it on two computers and the problem is identical.
April 26, 2016 - 3:17 PM
Can you tell us more?
Windows server? Linux server?
The package name?
Alex
April 26, 2016 - 3:38 PM
This is a Windows server.
I just found a solution. I reinstalled WaptServer and during configuration, I entered an IP address for both the "DNS Name" and the "IP Address." And it works now.
My DNS server was probably blocking it.
I don't know if this will help anyone, but everything is working correctly now. :P
Have a good day
