I've searched everywhere, but is there any documentation that allows me to import data and history from version 1.8 into a fresh 2.2 installation?
Regards
[RESOLVED] Data migration to new installation
- WAPT Expert
Hello Joël,
the easiest way is to update your existing installation and then migrate it to a new installation using the backup and restore documentation.
Regards,
Regards,
It works... it's indirectly related to the topic viewtopic.php?t=3165.
I tried backing up/restoring from version 1.8 to version 2.2, but I'm having a problem upgrading the database version.
I got my answer in that thread. The rest of the solution for the database upgrade is in the other thread.
Thanks, Denis
Thanks, Denis
System and Network Administrator at Domitia Habitat
