[RESOLVED] Update to Discovery: Error logging into the console
jlatieule
Registration: July 3, 2019 - 9:18 AM
August 11, 2022 - 10:18
I've made four attempts, each with the same result. Every time, I'm forced to restore the server to the previous snapshot.
I'm trying to update from the latest Community version to Discovery 2.2.
Everything seems to work correctly, but after the update, it's no longer possible to authenticate on the console with the "admin" account.
I've tried several combinations:
- Post-configuration: Password update or No update (to keep the old one)
- Console update: with complete uninstallation or everything automated by the Windows installer.
WAPT is installed on Debian 10.
How can I regain control of the console?
Sincerely
System and Network Administrator at Domitia Habitat
jlatieule
August 11, 2022 - 2:23 PM
I just tried importing the PostgreSQL database from the old server I'm trying to upgrade with a fresh installation.
Simply by loading the database with the same version of WAPT, it's no longer possible to connect to the new installation.
The problem likely lies there.
August 12, 2022 - 4:00 PM
Can you provide the version number of the database available on the web interface?
You can try a:
sudo -u wapt /opt/wapt/waptpython.sh
from waptserver.config import load_config
from waptserver.model import *
conf = waptserver.config.load_config('/opt/wapt/conf/waptserver.ini')
load_db_config(conf)
create_default_users(conf)
quit()
This allows you to recreate the admin account with the ACLs if it is not an admin account
jlatieule
August 12, 2022 - 4:36 PM
Hi Simon, glad to see you here after all these years in ICT ;-)
Here is the requested feedback:
Base status: OK (2.2.5.2)
And after running the Python code, I get this error message:
administrateur@serv-wapt:~$ sudo -u wapt /opt/wapt/waptpython.sh
[sudo] password for administrateur:
Python 3.8.13 (default, May 23 2022, 11:25:12)
[GCC 8.3.0] on linux
<playhouse.pool.PooledPostgresqlExtDatabase object at 0x7f7bb20678e0>
  File "<stdin>", line 1, in <module>
  File "/opt/wapt/waptserver/model.py", line 1246, in create_default_users
    if created or not admin_acls.acls.get('admin'):
AttributeError: 'NoneType' object has no attribute 'get'
>>> quit()
So I'm still having this authentication problem on the console ;-/
August 17, 2022 - 10:15
jlatieule wrote: August 12, 2022 - 4:36 PM Hi Simon, glad to see you here after all these years of ICT ;-)
Still here ;)
Okay, the database is stuck at 2.2.5.2
The problem therefore lies between the switch from 2.2.5.2 to 2.2.6.0
In the latest version of wapt, the base is 2.2.6.1
The code is ugly here because on line 3083 of model.py we have:
    finally:
        pass
So we're unlikely to see the mistake...
You can replace the code in model.py on line 3083 with:
    except:
        import traceback
        print(traceback.format_exc())
    finally:
        pass
then you can try a:
upgrade_db_structure(conf)
At least we'll see something
Also, what version of PostgreSQL do you have installed?
jlatieule
August 17, 2022 - 12:42
Indeed, we can see more information.
Regarding the PostgreSQL version:
postgres (PostgreSQL) 11.17 (Debian 11.17-0+deb10u1)
and the return of the upgrade:
<playhouse.pool.PooledPostgresqlExtDatabase object at 0x7fc32e401940>
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 3144, in execute_sql
    cursor.execute(sql, params or ())
psycopg2.errors.UndefinedFunction: function is_valid_jsonb(jsonb) does not exist
LINE 1: ...set value = to_jsonb(value::text)::text where not is_valid_j...
HINT:  No function matches the given name and argument types. You might need to add explicit type casts.
  File "/opt/wapt/waptserver/model.py", line 2987, in upgrade_db_structure
    wapt_db.execute_sql("""update hostauditdata set value = to_jsonb(value::text)::text where not is_valid_jsonb(value) and not is_valid_jsonb(replace(value,'''','"'));""")
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 3151, in execute_sql
    self.commit()
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 2917, in __exit__
    reraise(new_type, new_type(exc_value, *exc_args), traceback)
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 190, in reraise
    raise value.with_traceback(tb)
peewee.ProgrammingError: function is_valid_jsonb(jsonb) does not exist
August 17, 2022 - 3:36 PM
Okay, we've identified the problem.
I'll see about pushing a nightly build today.
jlatieule
August 17, 2022 - 3:44 PM
Cool, I managed to report a bug
. Do I need to restore version 1.8.2 and redo the update, or will it be a command I need to run?
August 18, 2022 - 6:01 PM
Normally, just an upgrade will suffice; the database will migrate correctly with the new code.
Could you try this one?
https://wapt.tranquil.it/wapt/nightly/w ... 5-3fd94bd1
jlatieule
August 22, 2022 - 5:16 PM
Thanks Simon,
I searched for the Debian repository address from https://wapt.tranquil.it/Debian/ but I'm completely out of touch on this subject.
How can I install the nightly build you suggested?
