Hello, I do have the old certificate in /opt/wapt/waptserver/ssl/. You need to move the existing key: `mkdir /root/oldkey` OK `mv /opt/wapt/waptserver/ssl/key.pem /root/oldkey/` OK `mv /opt/wapt/waptserver/ssl/cert.pem /root/oldkey/` OK Restart postconf: `/opt /wapt/waptserver/scripts/postconf.sh` OK Save the new key: `mkdir /root/new` OK `mv /opt/wapt/waptserver/ssl/key.pem /root/new/ ` OK `mv /opt/wapt/waptserver/ssl/cert.pem / root/new/` OK Replace the old certificate : `mv /root/oldkey/key.pem /opt/wapt/waptserver/ssl/` OK ` mv /root/oldkey/cert.pem /opt/wapt/waptserver/ssl/` OK ` systemctl restart nginx` OK Now you can Retrieve the public key: cat /root/new/cert.pem /opt/wapt/waptserver/ssl/cert.pem > /root/srvwapt.mydomain.lan.crt OK Retrieve the file /root/srvwapt.mydomain.lan.crt and place/replace the one in C:\Program Files (x86)\wapt\ssl\server\srvwapt.mydomain.lan.crt OK You can now generate a new agent (which will therefore contain the new file srvwapt.mydomain.lan.crt) OK When I run the command wapt-get update on the machine where I deployed the new agent, the SubjectAltNameWarning warning is still present.
[SOLVED] SubjectAltNameWarning
olaplanche
- Registration: January 26, 2017 - 11:11
- Installed WAPT version: 2.6.0.16795 Enterprise
- Server OS: Linux / Debian Bookworm
olaplanche
FYI: if I edit the new .crt file, I do indeed have the new and old certificates:
-----BEGIN CERTIFICATE-----
blablabla
-----END CERTIFICATE-----
blablablabla
blablabla
blablablabla
- WAPT Expert
Yes, so that's normal;
the end of the procedure is missing:
The following operations should only be performed if the new file
C:\Program Files (x86)\wapt\ssl\server\srvwapt.mydomain.lan.crt is indeed present
on all agents.
The following operations are performed:
mv /root/new/key.pem /opt/wapt/waptserver/ssl/
mv /root/new/cert.pem /opt/wapt/waptserver/ssl/
The goal of this operation is for the WAPT agent to accept both the old and new
certificates!
When the old certificate is present on the server side, it generates a warning.
on all agents.
certificates!
olaplanche
Okay, I get it!
I wanted to test before deploying the new agent to all the machines and completing the final steps of the procedure. I messed up... I just put the new certificate back in the /opt/wapt/waptserver/ssl/ folder and restarted nginx while testing on my test machine (with the new agent). Everything is OK, no more SubjectAltNameWarning warnings. I've put the old certificate back; all that's left is to deploy the new agent to all the machines and put the new certificate back in.
Thanks for your invaluable help.
