TeamViewer and console management
Omahaddict
Registration: Apr 20, 2016 - 3:15 p.m.
April 20, 2016 - 3:53 PM
I have a Corporate license for TeamViewer 9 and I use WAPT for centralized management of my configurations.
I'm encountering a problem: I can't link the computer to the TeamViewer account without user intervention. During installation, there's no issue; I can see the PC linked to my company account. However, upon restarting the machine, TeamViewer asks me for a password to install unattended access.
I created a package using an MSI file that is already customized (it automatically links to my account).
Have you ever encountered this problem? If so, how did you work around it?
Another question: by right-clicking on computers in the inventory, you can connect via VNC or RDP. Is it possible to add entries to this context menu? (You see where I'm going with this, right? Adding Teamviewer connectivity, for example, and then we have a console that centralizes everything!)
Thank you for your help and congratulations to the developers and contributors who are leading this project.
April 20, 2016 - 4:16 PM
Omahaddict wrote:Hello,
I'm facing a problem: I can't link the computer to the TeamViewer account without user intervention. During installation, there's no problem; I can see the PC linked to my company account. However, upon restarting the machine, TeamViewer asks me for a password to install unattended access.
I don't know TeamViewer, so I have trouble understanding your problem, but you should ask them for the procedure for a silent installation.
Omahaddict wrote: I created a package using an MSI file that's already customized (it automatically links to my account).
How was this MSI file created? Is it an official TeamViewer procedure?
Omahaddict wrote: Another question: by right-clicking on computers in the inventory, you can connect via VNC or RDP. Is it possible to add entries to this context menu? (You know what I'm going with, right? Add "Connect via TeamViewer," for example, and then we'd have a console that centralizes everything!)
The Wapt source code is available on GitHub here: https://github.com/tranquilit/WAPT
By following the procedure in README.md you can modify the console by opening the waptconsole.lpr file with codetyphon
In the uwaptconsole.pas file you can replace
ShellExecute(0, '', PAnsiChar('C:\Program Files\TightVNC\tvnviewer.exe'),
PAnsichar(ip), nil, SW_SHOW)
Because you want
I managed to add a power button the other day using this method
Omahaddict wrote: Thank you for your help and congratulations to the developers and contributors who are leading this project.
Floflobel
Registration: Oct 15, 2015 - 5:32 p.m.
April 20, 2016 - 7:50 PM
I'm facing the same problem; I can't seem to do it silently. A pop-up keeps appearing asking for permission.
I'll be following your thread closely ;) !
Omahaddict
April 21, 2016 - 10:08 AM
Thanks Simon for the information.
I'm currently retrieving the sources. I'll look into it.
Floflobel wrote:Hello,
I'm facing the same problem; I can't seem to do it silently. I always get a pop-up asking for permission.
OK, nothing's stopping you from continuing the investigation, right? :lol:
Are you also on V9? Are you talking about deployment via Wapt or via the classic MSI+GPO?
I'll get back to you as soon as I've looked into it a bit more.
Floflobel
April 21, 2016 - 10:50
Absolutely, we're still looking into it, but it's no longer our priority.
We install TeamViewer when we deploy an image to a machine. But we have to be physically present at the machine; it displays a pop-up asking us to authorize it.
Group Policy Objects (GPOs) aren't possible.
Regarding your password problem, you'll need to generate a .reg and a .msi file, like I did, but you'll be stuck in the same place...
Omahaddict
April 27, 2016 - 09:58
Back after some tests and investigations.
The silent installation of TeamViewer works. The link to my account is successful without any pop-ups.
For those interested, this requires adding the following key to the registry in addition to the information exported from the host client
[HKEY_LOCAL_MACHINE\SOFTWARE\TeamViewer\Version9\DefaultSettings]
"HostInfoDialog"=dword:00000000
However, being a beginner in Python, I can't seem to get a custom setup working...
I followed the documentation but I encountered several problems/error messages when opening the files
c:\tranquilit\wapt\waptconsole\waptconsole.lpr
And
c:\tranquilit\wapt\waptserver\postconf\waptserverpostconf.lpr
I chose to ignore the changes suggested by Simon (replacing VNC with the path to my TeamViewer executable) and started the compilation. After the entire procedure, I managed to generate an executable with InnoSetup. The installation completed without error, but when I open the console, I get an error:
Thank you for your help.
April 27, 2016 - 12:02
Hi for the TSOGRID
The documentation states:
Launch CodeTyphon
. Open a package file (.lpk).
Open the following packages successively and compile them:
pltis_sogrid.lpk (IDE installation required).
Did you open the package?
Otherwise, for the reference error, try right-clicking on your WaptConsole, then selecting Properties, and in Compatibility, check "Run as administrator".
Omahaddict
April 27, 2016 - 1:32 PM
Okay, it works, I can successfully launch the recompiled console.
However, my TeamViewer isn't working the way I want it to... :?
To initiate the connection via the command line, simply pass the argument -i %computername% or -i %ip%
Here is the modified code from uwaptconsole.pas
procedure TVisWaptGUI.ActVNCExecute(Sender: TObject);
var
  ip: ansistring;
begin
  if (Gridhosts.FocusedRow <> nil) and
    (Gridhosts.FocusedRow.S['host.connected_ips'] <> '') then
  begin
    ip := GetReachableIP(Gridhosts.FocusedRow['host.connected_ips'],5900);
    if ip<>'' then
      ShellExecute(0, '', PAnsiChar('c:\Program Files (x86)\TeamViewer\Version9\TeamViewer.exe -i'),
    else
      ShowMessage(rsNoReachableIP);
  end;
end;
procedure TVisWaptGUI.ActVNCUpdate(Sender: TObject);
begin
  try
    ActVNC.Enabled := (Gridhosts.FocusedRow <> nil) and
      (Gridhosts.FocusedRow.S['host.connected_ips'] <> '') and
      FileExists('c:\Program Files (x86)\TeamViewer\Version9\TeamViewer.exe -i');
  except
    ActVNC.Enabled := False;
  end;
end;
But I imagine the argument is not in the right place since nothing happens (the menu is greyed out), if I don't put the -i my teamviewer console opens correctly though.
As a follow-up question, to replace VNC with Teamviewer in the context menu, do I simply need to replace all the VNC entries in this file with Teamviewer?
April 27, 2016 - 3:13 PM
Omahaddict wrote:Okay, it works, I can successfully launch the recompiled console.
var
  ip: ansistring;
begin
  begin
    if ip<>'' then
    else
  end;
end;
begin
  try
  except
  end;
end;
I'm not very familiar with Free Pascal; I only recently discovered it while playing around with Wapt when I wanted to add my shutdown functionality. I'm just feeling my way through it
A quick internet search revealed:
http://wiki.freepascal.org/Executing_Ex...nd_WinExec
http://forum.lazarus.freepascal.org/ind ... ic=25392.0
The guy on the forum does it like this:
MyProcess.Executable := 'D:\SomeDir\abc.exe';
MyProcess.Parameters.Add('D:\SomeDir\Data\ritem.dat');
MyProcess.Execute;
If that helps...
Omahaddict wrote: Follow-up question: to replace VNC with Teamviewer in the context menu, do I simply need to replace all the VNC entries in this file with Teamviewer?
Rename directly using the CodeTypo interface
Omahaddict
April 28, 2016 - 11:36
It works! :D
Here is the modified code:
    ip := GetReachableIP(Gridhosts.FocusedRow['host.connected_ips'],5938);
    if ip<>'' then
    ShellExecute(0, '', PAnsiChar('c:\Program Files (x86)\Teamviewer\Version9\Teamviewer.exe'),
        PAnsichar('-i' + ip), nil, SW_SHOW)
However, I am unable to rename the menus... I have an error when starting the recompiled console, it is still looking for an actvnc (which I renamed to actteamviewer).
I renamed everyone who was in uwaptconsole.pas, surely there are references elsewhere?
I didn't understand your advice:
sfonteneau wrote: Rename directly using the codetyphon interface
Where in the console are you doing this?
Thanks for your advice, Simon, I've made great progress! ;)
