Hi Joel,
the nightly updates are here: https://wapt.tranquil.it/wapt/nightly/
[RESOLVED] Update to Discovery: Error logging into the console
- WAPT Expert
Thanks Denis for the feedback, but I didn't express my need clearly.
The question was more along the lines of: what do I need to change in the /etc/apt/sources.list.d/wapt.list file to install the nightly version https://wapt.tranquil.it/wapt/nightly/w ... 5-3fd94bd1?
Unless I need to install the .deb files manually (no problem). If so, which ones?
I'm eager to test this version.
System and Network Administrator at Domitia Habitat
- WAPT Expert
Hi Joël,
there's no deb repository for nightly builds, only for releases and RCs. So you have to download the deb files and install them manually.
There have been quite a few changes in version 2.3, so it's best to avoid it for now. I think Simon was referring to the latest version, 2.2.2: https://wapt.tranquil.it/wapt/nightly/w ... -3fd94bd1/
Regards,
Regards,
Hello team
I'm a bit late, but I just installed the nightly build and there seems to be a dependency issue with GLIBC
@serv-wapt:~$ sudo /opt/wapt/waptserver/scripts/postconf.sh
[sudo] password for administrateur:
/opt/wapt/bin/python: /lib/x86_64-linux-gnu/libm.so.6: version `GLIBC_2.29' not found (required by /opt/wapt/bin/../lib/libpython3.8.so.1.0)System and Network Administrator at Domitia Habitat
- WAPT Expert
I recognize the message.
In my opinion, you made a small mistake and installed waptserver deb10 on a deb11 or something like that.
I often make that mistake.
That's exactly it, I hadn't seen your reply and I ended up upgrading Debian 10 to 11, then I upgraded WAPT from 1.8 to 2.2, and then switched to the nightly build.
I just need to update the agent and everything will be perfect.
I can confirm that this version fixes my problem. I haven't noticed any bugs.
WAPT Server version: 2.2.2
WAPT Agent version: 1.8.2.7373
WAPT Setup version: 2.2.2.12388
WAPT Deploy version: 2.2.2.12388
Database status: OK (2.2.6.1)
Disk space: 31.57% free
You need to get the .deb file that corresponds to your Debian version: this one if you're on Buster: https://wapt.tranquil.it/wapt/nightly/w ... -amd64.deb
then run the command `sudo dpkg --install tis-waptserver-2.2.2.12405-3fd94bd1-debian-10-amd64.deb`.
I had the same problem, and I was able to access my console on my test server (before migrating my production server) thanks to this new build (Debian 11 amd64).
Thanks to the whole team for their responsiveness!
