Migration 1.8 -> 2.2: certificate signing problem
jlatieule
Registration: July 3, 2019 - 9:18 AM
August 30, 2022 - 5:22 PM
I've tried quite a few things since this morning, but there's still no noticeable improvement. I suspect I have a certificate problem.
Here's what's been done to move the old server from our production VLAN to the new one in the DMZ:
- Updated Debian 10 to Debian 11
- Updated WAPT 1.8 to 2.2
- Installed Debian 11 on the new server
- Installed WAPT 2.2 on the new server
- Migrated data according to the documentation: https://www.wapt.fr/fr/doc/wapt-server-backup.html
- Upgraded the console; everything is working correctly
- Updated the agent
- Resigning packages via the console failed; I tried using the command line: https://www.wapt.fr/fr/doc/wapt-command ... ackage-cmd
Since then, the machines have lost the list of installed packages, and I still can't sign the packages. I have an error message visible in both screenshots.
On an administration machine where the console hasn't been updated to WAPT 2.2, I still have access to the packages.
I'm stumped... I still have my certificates and passwords from 2019/2020; it's as if they're not being recognized correctly.
Unless the certificates and waptserver.ini file from the old server, placed on the new server in the /opt/wapt/conf folder, are causing the problem?
It's beyond me :-/
System and Network Administrator at Domitia Habitat
August 30, 2022 - 10:16 PM
When re-signing through the console, we check that the old package is correctly signed in its previous version, to avoid a man-in-the-middle attack.
Apparently the old certificate from the 7zip package is not recognized on the machine: the certificate (present in the WAPT folder of the package) is indeed present in "C:\Program Files (x86)\wapt\ssl" on the machine?
jlatieule wrote: ↑August 30, 2022 - 5:22 PM Since then, the machine packages have lost the list of installed packages
It's strange; it might be an inventory retrieval issue if the agent isn't up to date, but the packages shouldn't just disappear on their own like that
jlatieule
August 31, 2022 - 07:06
Thanks Simon,
I think there are two problems to fix simultaneously.
The agent isn't deployed yet, so I think the lack of station updates will resolve itself.
Regarding the certificates, the private and public keys are in c:/private.
Back at work, I'll check the contents of the package and the SSL folder. The public key is probably missing somewhere.
jlatieule
August 31, 2022 - 4:30 PM
Hi Simon,
That was it. The public key wasn't in "C:\Program Files (x86)\wapt\ssl".
I rebuilt the agent with it and it worked perfectly.
There are still some packages where I'm getting Python errors, probably due to the version upgrade. I still have a few package modifications to make and then it will be migrated correctly.
