Yes, perfect, thank you. I did need to add the line for the update at the beginning.
One last question: have you ever encountered this issue? I can't seem to deploy it on PCs with a USB-C dock.
[SOLVED] OS deployment + post-install script
- WAPT Expert
the USB-C drivers are probably missing from the WinPE image,
depending on the error you're getting.
- WAPT Expert
copy the file
towards
then add the drivers to the WIM file:
then copy towards
You can now regenerate the winpe from the wapt console
C:\Program Files (x86)\Windows Kits\10\Assessment and Deployment Kit\Windows Preinstallation Environment\amd64\en-us\winpe.wim Code: Select all
c:\waptdev\winpe.wimCode: Select all
Dism /Mount-Image /ImageFile:"c:\waptdev\winpe.wim" /index:1 /MountDir:"C:\mountpe"
Dism /Add-Driver /Image:"C:\mountpe" /Driver:"C:\SampleDriver\driver.inf"
Dism /Unmount-Image /MountDir:"C:\mountpe" /commit
Dism /Export-Image /SourceImageFile:c:\waptdev\winpe.wim /SourceIndex:1 /DestinationImageFile:c:\waptdev\winpe_cleaned.wimCode: Select all
