[RESOLVED] IPXE Problem: Network unreachable
t.heroult
Registration: December 8, 2020 - 10:13 AM
September 9, 2022 - 9:41 AM
Good morning
Since this morning, we've been experiencing strange behavior when booting from PXE.
We tried it with VMs and physical machines and it always gives the same result:
Even after restarting the WAPT server, nothing changes.
Any ideas?
Tom
EDIT: Problem with DHCP server desynchronization
Consoles: Windows 10 & 11
Infrastructure: Windows
September 9, 2022 - 9:57 AM
the IPXE has been successfully retrieved, so the first step is OK (TFTP part).
Now the IPXE is retrieving its configuration (it's making another DHCP request to get the IPXE script URL).
Has this already worked for you, or is this a new setup?
t.heroult
September 9, 2022 - 12:57
It's been in place for a while now, we've already mastered a few machines with it.
September 9, 2022 - 6:40 PM
t.heroult wrote: ↑09 Sep 2022 - 12:57 It's been in place for a while now, we've already mastered a few machines with it.
Interesting, has anything changed on your end in the meantime? A Wapt upgrade? A DHCP configuration modification?
Do you see anything in the nginx logs on the wapt server?
tail -f /var/log/nginx/access.log
t.heroult
September 12, 2022 - 10:06 AM
Hello Simon
No, there are no changes in our system or in WAPT.
That's what's really weird...
Here is the result of the command:
root@SRVWAPT:~# tail -f /var/log/nginx/access.log
172.18.0.7 - - [12/Sep/2022:10:02:15 +0200] "POST /update_host HTTP/1.1" 200 1204 "-" "wapt/2.2.2"
172.16.2.173 - - [12/Sep/2022:10:02:28 +0200] "HEAD /ping HTTP/1.1" 200 0 "-" "wapt/2.2.2"
172.16.2.173 - - [12/Sep/2022:10:02:30 +0200] "POST /update_host HTTP/1.1" 200 1276 "-" "wapt/2.2.2"
172.16.2.103 - - [12/Sep/2022:10:02:37 +0200] "HEAD /waptwua/wsusscn2.cab HTTP/1.1" 200 0 "-" "wapt/2.2.2"
172.16.10.69 - - [12/Sep/2022:10:02:38 +0200] "HEAD /ping HTTP/1.1" 200 0 "-" "wapt/2.2.2"
172.16.10.69 - - [12/Sep/2022:10:02:40 +0200] "POST /update_host HTTP/1.1" 200 1276 "-" "wapt/2.2.2"
172.17.1.35 - - [12/Sep/2022:10:02:46 +0200] "HEAD /ping HTTP/1.1" 200 0 "-" "wapt/2.2.2"
172.17.1.35 - - [12/Sep/2022:10:02:47 +0200] "POST /update_host HTTP/1.1" 200 1270 "-" "wapt/2.2.2"
172.17.1.19 - - [12/Sep/2022:10:02:58 +0200] "HEAD /ping HTTP/1.1" 200 0 "-" "wapt/2.2.2"
172.17.1.19 - - [12/Sep/2022:10:02:59 +0200] "POST /update_host HTTP/1.1" 200 1270 "-" "wapt/2.2.2"
172.16.1.127 - - [12/Sep/2022:10:03:19 +0200] "GET /rules.json HTTP/1.1" 200 2 "-" "wapt/2.2.2"
172.16.1.127 - - [12/Sep/2022:10:03:19 +0200] "HEAD /waptwua/wsusscn2.cab HTTP/1.1" 200 0 "-" "wapt/2.2.2"
172.16.1.127 - - [12/Sep/2022:10:03:19 +0200] "GET /licences.json HTTP/1.1" 200 2658 "-" "wapt/2.2.2"
172.16.1.127 - - [12/Sep/2022:10:03:19 +0200] "HEAD /wapt/Packages HTTP/1.1" 200 0 "-" "wapt/2.2.2"
172.16.1.127 - - [12/Sep/2022:10:03:19 +0200] "GET /wapt/Packages HTTP/1.1" 200 134009 "-" "wapt/2.2.2"
172.16.1.127 - - [12/Sep/2022:10:03:20 +0200] "HEAD /wapt-host/xxxxxxxxxxx.local.wapt HTTP/1.1" 200 0 "-" "wapt/2.2.2"
172.16.1.127 - - [12/Sep/2022:10:03:20 +0200] "GET /rules.json HTTP/1.1" 200 2 "-" "wapt/2.2.2"
172.16.1.127 - - [12/Sep/2022:10:03:20 +0200] "HEAD /waptwua/wsusscn2.cab HTTP/1.1" 200 0 "-" "wapt/2.2.2"
172.16.1.127 - - [12/Sep/2022:10:03:20 +0200] "GET /licences.json HTTP/1.1" 200 2658 "-" "wapt/2.2.2"
172.16.1.127 - - [12/Sep/2022:10:03:20 +0200] "HEAD /wapt/Packages HTTP/1.1" 200 0 "-" "wapt/2.2.2"
172.16.1.127 - - [12/Sep/2022:10:03:20 +0200] "HEAD /ping HTTP/1.1" 200 0 "-" "wapt/2.2.2"
172.16.1.127 - - [12/Sep/2022:10:03:21 +0200] "POST /update_host HTTP/1.1" 200 1270 "-" "wapt/2.2.2"
172.16.10.69 - - [12/Sep/2022:10:03:31 +0200] "HEAD /ping HTTP/1.1" 200 0 "-" "wapt/2.2.2"
172.16.10.69 - - [12/Sep/2022:10:03:33 +0200] "POST /update_host HTTP/1.1" 200 1276 "-" "wapt/2.2.2"
172.16.3.11 - - [12/Sep/2022:10:03:48 +0200] "HEAD /ping HTTP/1.1" 200 0 "-" "wapt/2.2.2"
172.16.3.11 - - [12/Sep/2022:10:03:50 +0200] "POST /update_host HTTP/1.1" 200 1268 "-" "wapt/2.2.2"
172.16.2.89 - - [12/Sep/2022:10:03:56 +0200] "HEAD /ping HTTP/1.1" 200 0 "-" "wapt/2.2.2"
172.16.2.89 - - [12/Sep/2022:10:03:57 +0200] "POST /update_host HTTP/1.1" 200 1274 "-" "wapt/2.2.2"
172.16.1.201 - - [12/Sep/2022:10:04:00 +0200] "HEAD /ping HTTP/1.1" 200 0 "-" "wapt/2.2.2"
172.16.1.201 - - [12/Sep/2022:10:04:02 +0200] "POST /update_host HTTP/1.1" 200 1276 "-" "wapt/2.2.2"
172.17.1.19 - - [12/Sep/2022:10:04:09 +0200] "HEAD /ping HTTP/1.1" 200 0 "-" "wapt/2.2.2"
172.17.1.19 - - [12/Sep/2022:10:04:10 +0200] "POST /update_host HTTP/1.1" 200 1269 "-" "wapt/2.2.2"
172.16.1.219 - - [12/Sep/2022:10:04:10 +0200] "HEAD /ping HTTP/1.1" 200 0 "-" "wapt/2.2.2"
172.16.50.144 - - [12/Sep/2022:10:04:11 +0200] "HEAD /ping HTTP/1.1" 200 0 "-" "wapt/2.2.2"
172.16.50.144 - - [12/Sep/2022:10:04:12 +0200] "POST /update_host HTTP/1.1" 200 1265 "-" "wapt/2.2.2"
172.16.1.219 - - [12/Sep/2022:10:04:12 +0200] "POST /update_host HTTP/1.1" 200 1264 "-" "wapt/2.2.2"
172.17.1.16 - - [12/Sep/2022:10:04:12 +0200] "HEAD /ping HTTP/1.1" 200 0 "-" "wapt/2.2.2"
172.17.1.16 - - [12/Sep/2022:10:04:13 +0200] "POST /update_host HTTP/1.1" 200 1270 "-" "wapt/2.2.2"
172.16.1.161 - - [12/Sep/2022:10:04:14 +0200] "HEAD /ping HTTP/1.1" 200 0 "-" "wapt/2.2.2"
September 12, 2022 - 10:41
cat /var/log/nginx/access.log |grep -i pxe
will be better for searching for PXE in access.log
t.heroult
September 12, 2022 - 11:52
There are no results there.
September 12, 2022 - 1:16 PM
Same answer as here:
viewtopic.php?p=10982#p10982
It's strange that it crashes without any changes (no Wapt upgrade, no DHCP configuration modification).
t.heroult
September 12, 2022 - 2:44 PM
Unfortunately, that doesn't help.
The entire DHCP configuration seems OK; a test returns the correct filename (ipxe.efi) and the correct IP address.
The file is correctly located in /var/www/wads/pxe (dated 5/8/22).
I don't know what to check next.
t.heroult
September 12, 2022 - 3:04 PM
Update: By pausing at the beginning of the boot process, it seems that the file is successfully retrieved
The file size matches what I see in filezilla on the Wapt server.
