Console access problem
Raphael
Registration: Nov 11, 2014 - 11:42
November 11, 2014 - 11:49
Hello. I'm a teacher and I manage the computer network in a high school in the Basque Country.
I'm not sure if this is the right place to post, but I'm having a problem after installing the server.
Access to the console is impossible, error http/1.1 404 not found: see attached image.
Access to locahost:8088 works.
Any ideas?
The PC is running Windows Server 2003, with things installed like an OfficeScan server, for example.
Thanks.
Frédéric Bonnier
Registration: June 23, 2014 - 10:10
November 12, 2014 - 11:42
Hello Raphaël,
Regarding the problems with the WAPT tool, I recommend you consult the mailing list (http://lists.tranquil.it/listinfo/wapt) which centralizes these types of incidents. Furthermore, the entire community can help you resolve this issue.
This forum is primarily intended to gather your feedback on this solution, so please feel free to share your thoughts.
Frédéric BONNIER
TRANQUIL IT SYSTEMS
