Cleaning, or how to regain control of your fleet.
kukrapoc
Registration: March 30, 2016 - 09:00
March 31, 2016 - 2:30 PM
I'm currently testing the very promising Wapt.
I'm taking over a network of approximately 400 machines (XP, Win7 32 & 64) and would like to know the best method for "cleaning up" the workstations before properly deploying the same software version via Wapt. A
concrete example on one machine: Deployment via GPO of the agent, no problem. Then, testing the installation of the tis-java8 package, no problem. However, the old Java version already installed (7) is still there. :(
Before preparing a company-wide rollout, I would like to master the uninstallation of the software already installed on the workstations in order to return to the most standardized and homogeneous network possible.
I hope I have been clear about my request.
I'll continue to inquire.
Thank you and have a good day everyone. ;)
April 1, 2016 - 9:10 AM
Hello kukrapoc
For "well-made" software, you can use the uninstallkey to uninstall the software beforehand.
Example:
      softname = 'Scribus'
      versionsoft = '15.007.20033'
      check_installed_soft = installed_softwares(softname)
      if check_installed_soft:
                if Version(uninstall['version']) < Version(versionsoft):
                   run(cmd)
I do indeed do this with the packages on my repository, and especially with Java:
It is available here
https://wapt.lesfourmisduweb.org/wapt/s ... 2_all.wapt
kukrapoc
April 1, 2016 - 4:16 PM
Hello and thank you for your reply.
If I understand correctly, I need to create a .bat file containing my uninstall code and then create a package with it?
Sorry if I'm a novice, but I've just started using this software and it's not very clear yet...
Thanks anyway. ;)
April 2, 2016 - 5:15 PM
Hello, no, you can add it to the beginning of your package's setup.py file.
Here are some documentation resources for creating packages:
- http://dev.tranquil.it/scenari/guide_cr ... _wapt.html
- https://wiki.lesfourmisduweb.org/index. ... aquet_wapt
- http://reseaux85.fr/index.php?title=Cr% ... quets_WAPT
kukrapoc
April 6, 2016 - 2:16 PM
Thank you for your reply.
However, what about software that we want to permanently uninstall?
Is it possible to create a package that uninstalls only one (or more) program(s)?
Thank you and have a good day. ;)
April 6, 2016 - 3:51 PM
Good morning
You can create a package named "tis-uninstallsoft"
And include inside.
def install() :
                   run(cmd)
      softname = 'inkscape'
                   run(cmd)
!! Warning However !!The script doesn't go into detail. It will remove all software that contains the words "Scribus" and "Inkscape".
Also, be careful!
Uninstallation will only work if the software's uninstall key is silent.
Indeed, if the software's uninstall key is not silent, it will not work, waiting indefinitely for user action.
kukrapoc
April 7, 2016 - 6:13 PM
Thank you so much for taking the time to reply.
I'll try all of that out.
See you soon! ;)
so37
Registration: Apr 10, 2016 - 1:43 p.m.
May 2, 2016 - 10:33 PM
Hello Sfonteneau, thank you for the information you provided. You mentioned that it won't work for uninstalls using a non-silent uninstallkey. Can we replace cmd with msiexec /x xxxx.msi?
May 3, 2016 - 08:59
Yes, in the example, cmd represents the command line to be launched, and we will look for the one from uninstallkey
If it's not silent, this can easily be replaced by a hard-mounted control
