[SOLVED] Uninstalling the Brave browser
Stenon
Registration: June 2, 2016 - 8:04 AM
October 24, 2022 - 3:36 PM
I'm trying to uninstall the "Brave" package (created using Package Template), but unfortunately it requires an action, and I haven't found a silent option... Do you have any ideas?
Many thanks in advance,
Samuel
October 24, 2022 - 4:45 PM
https://silentinstallhq.com/brave-brows ...-to-guide/
Here it says:
"%ProgramFiles%\BraveSoftware\Brave-Browser\Application\w.x.y.z\Installer\setup.exe" --uninstall --system-level --force-uninstall
Stenon
October 25, 2022 - 8:36 AM
Thank you, it works!
And here is my code for the road:
    # Declaring local variables
    # Installing the software
    print("Installing: Brave_installer-x64.exe")
    install_exe_if_needed('brave_installer-x64.exe',
        silentflags='--install --silent --system-level',
        key='BraveSoftware Brave-Browser',
        min_version='1.3.361.133'
    def killsoft():
      soft = "BRAVE"
      if isrunning(soft):
        print ("closing %s" % soft)
        killalltasks(soft)
    killsoft()
    uninstaller_dir = makepath(programfiles, "BraveSoftware", "Brave-Browser", "Application", "106.1.44.112", "Installer")
    uninstaller_path = makepath(uninstaller_dir, "setup.exe")
    run('"%s" --uninstall --system-level --force-uninstall' % uninstaller_path,accept_returncodes=[3,19])
