I can't get a Cisco Webex msi package to work (not Cisco Webex Meeting, which is already in the online repository)
In the explanatory videos, there's an option to modify the arguments and the uninstallkey in the wizard, but it's greyed out for me...
Can you help me create a working setup.py file?
Here is my essay
uninstallkey=["{32E8818C-AA8B-5494-9CA9-FA0E093140B8}"]
print('installation de Cisco Webex')
run('msiexec /qn "webex.msi" ACCEPT_EULA=TRUE ALLUSERS=1')Here is the error log
File "C:\Program Files (x86)\wapt\common.py", line 4057, in install_wapt
File "C:\Windows\TEMP\waptbonvc41t\setup.py", line 8, in install
File "C:\Program Files (x86)\wapt\common.py", line 3834, in run
File "C:\Program Files (x86)\wapt\waptutils.py", line 2114, in run
raise TimeoutExpired(cmd, ''.join(output), timeout)
waptutils.TimeoutExpired: Command 'msiexec /qn "webex.msi" ACCEPT_EULA=TRUE ALLUSERS=1' timed out after 600 seconds with output ''''
Here is the Webex link
https://binaries.webex.com/WebexTeamsDe ... /Webex.msi
Thank you for everything!
