[SOLVED] Microsoft Office 2016 Audit Issue
dj41ph4
Registration: Oct 26, 2022 - 2:02 p.m.
October 31, 2022 - 2:03 PM
I'm having a problem at the end of the Microsoft Office installation
I have this error message in the package audit log
Here's my setup
r"""
    # Declaring local variables
    # Installing the software
    print("Installation Office 2016 VDB")
run('"setup.exe" /adminfile VDB.MSP', timeout = 1200)
Here's my mistake
Auditing OFFICE2016
Audit aborted due to exception: Command '"setup.exe" /adminfile VDB.MSP' returned non-zero exit status 1.
Output:'"setup.exe"' n'est pas reconnu en tant que commande interne
ou externe, un programme exécutable ou un fichier de commandes.
Can you help me?
Thank you in advance
t.heroult
Registration: December 8, 2020 - 10:13 AM
October 31, 2022 - 2:25 PM
Hello
, it seems that this means the agent doesn't know where the setup.exe file is located.
Is it in the package?
In a subfolder of the package, or in the root directory?
Regards,
Tom
Server: WAPT Enterprise 2.6.1.17786 on Debian
Consoles: Windows 10 & 11
Infrastructure: Windows
dj41ph4
November 1, 2022 - 10:24 AM
The installation was correct, but there was still an auditing problem
I changed the code and haven't had any problems since
softname = 'Microsoft Office Standard 2016'
pgmsoffice = programfiles
        print('Installation Office 2016')
        cmd = '"setup.exe" /adminfile "silent.msp"'
        print('Repair and add component to ' + softname)
        cmd = 'msiexec.exe /p silent.msp'
        error(' %s has been installed but the uninstall key can not be found' % softname)
    #Activation
    pathosppvbs32 = makepath(pgmsoffice,'Microsoft Office','Office16','OSPP.VBS')
    if 'ERROR' in run('cscript "%s" /dstatus'  % pathosppvbs32):
        print("Running activation of " + softname)
        resultact = run('cscript "%s" /act' % pathosppvbs32)
            error('Activation did not work : ' + resultact)
        print('Already activated Product')
November 8, 2022 - 4:41 PM
Thanks dj41ph4 for your feedback,
