I'm currently testing on Windows Server 2019 and WAPT 2.2 for self-service application deployment only.
I'd like to make the ultravnc package available, but without installing the VNC viewer component. Additionally, I'd like to set a default password.
Is it possible to modify the package installation parameters?
I see some options in setup.py, but I don't understand them.
Thank you in advance.
Regards.
[RESOLVED] tis-ultravnc package
Good morning
It's relatively simple.
First, you need to create your configuration file (ultravnc.ini) with the settings and the encrypted password.
Put it in the package and once the setup is complete, you use a filecopyto() to overwrite the ini file with the one from the package.
As for vncviewer.exe, once the setup is complete, simply run a removefile() and it's done.
removefile(makepath(install_location("Ultravnc2_is1"),"vncviewer.exe"))Server: WAPT Enterprise 2.6.1.17870 on Debian
Consoles: Windows 10 & 11
Infrastructure: Windows
thank you for your reply. Having been away for a few days, I haven't been able to test your solution or respond sooner.
I'll get to testing everything as soon as possible and keep you updated.
In any case, thank you for taking the time to reply.
I just did another test with my test server: it works!!
There was just a small syntax error:
The "underscore" is missing between remove and file.
Thank you so much.
remove_file(makepath(install_location("Ultravnc2_is1"),"vncviewer.exe"))Thank you so much.
It all comes down to very little, doesn't it?
