Reporting - "Last connection" field
Share your SQL query ideas for reporting in the WAPT Enterprise console here
lutech
Registration: February 22, 2022 - 10:27
July 6, 2022 - 11:19
I'm trying to identify the SQL field "Last Connection" (image attached) so I can create a report listing the last connection dates of the PCs.
Thank you.
2022-07-06 11_17_43-Clipboard.png (17.99 KB) Viewed 17602 times
t.heroult
Registration: December 8, 2020 - 10:13 AM
November 4, 2022 - 1:59 PM
Good morning
Right-clicking on the tab bar gives you a list of displayable items and their names; that should help.
2022-11-04 13_57_36-.png (15.67 KB) Viewed 16282 times
Consoles: Windows 10 & 11
Infrastructure: Windows
November 8, 2022 - 4:22 PM
Hello everyone,
this value update is likely to change soon. WebSocket updates have been moved to RAM-only mode to avoid overly frequent updates. We'll see if we can maintain batch synchronization of the column every few minutes to ensure backward compatibility.
Regards,
