Apparently so...
I had set up the GPO and tested it on a machine, and it worked... but when I installed the certificate (valid for our site), the GPO stopped running, so I tried running the command manually, encountering the errors mentioned in the previous post. By reverting to the old (self-signed) certificate, the command runs correctly, and the agent is deployed on the test machine.
Is there a step I missed when installing/copying my certificate onto the Debian server?
Some details: /etc/nginx/site-enabled/wapt.conf
server {
listen 80;
listen [::]:80;
server_name _;
return 301 https://$host$request_uri;
server {
listen 443 ssl;
listen [::]:443 ssl;
server_name _;
#server_name wapt.site.fr;
# BACKUP certificat installation WAPT => autosigné
#ssl_certificate "/opt/wapt/waptserver/ssl/cert.pem";
#ssl_certificate_key "/opt/wapt/waptserver/ssl/key.pem";
# Certificat site.fr => pour notre site ici
ssl_certificate "/opt/wapt/waptserver/ssl/cert+CA-site.fr.pem";
ssl_certificate_key "/opt/wapt/waptserver/ssl/wildcard-site.fr.pem";
ssl_protocols TLSv1.2;
ssl_dhparam "/etc/ssl/certs/dhparam.pem";
ssl_prefer_server_ciphers on;
ssl_ciphers 'EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH';
ssl_stapling on;
ssl_stapling_verify on;
ssl_session_cache none;
ssl_session_tickets off;
# HSTS (ngx_http_headers_module is required) (63072000 seconds)
add_header Strict-Transport-Security "max-age=63072000" always;
#ssl_client_certificate "/opt/wapt/conf/ca-wapt.site.fr.crt";
#ssl_crl "None";
#ssl_verify_client optional;
gzip_min_length 1000;
gzip_buffers 4 8k;
gzip_http_version 1.0;
gzip_disable "msie6";
gzip_types text/plain text/css application/json;
gzip_vary on;
index index.html;
client_max_body_size 12288m;
client_body_timeout 1800;
# sub instances
include /opt/wapt/conf/wapt.d/*.conf;
location /static {
alias "/opt/wapt/waptserver/static";
location /ssl {
alias "/var/www/ssl";
# not protected URL
location ~ ^/(wapt/waptsetup.*.exe|wapt/waptagent.exe|wapt/waptdeploy.exe|sync.json|rules.json|licences.json)$ {
add_header Cache-Control "store, no-cache, must-revalidate, post-check=0, pre-check=0";
add_header Pragma "no-cache";
root "/var/www";
# not protected URL
location /wads {
alias "/var/www/wads";
# SSL protected URL
location ~ ^/(wapt/.*|waptwua/.*|wapt-diff-repos/.*)$ {
# be sure these headers are not forwarded
proxy_set_header X-Ssl-Client-Dn "";
proxy_set_header X-Ssl-Authenticated "";
root "/var/www";
# we don't want to expose our list of computers in case someone scan this folder.
location /wapt-host/Packages {
return 403;
location ~ ^/(wapt-host/.*)$ {
log_not_found off;
root "/var/www";
location ~ ^/.*_kerberos$ {
return 403;
location / {
add_header X-Remote-IP $remote_addr;
proxy_http_version 1.1;
proxy_request_buffering off;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_pass http://127.0.0.1:8080;
location /socket.io {
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "Upgrade";
proxy_pass http://127.0.0.1:8080/socket.io;
THANK YOU SO MUCH!
