[SOLVED] Autodesk AutoCAD 2023.1.2 Package
olaplanche
Registration: January 26, 2017 - 11:11
December 2, 2022 - 4:23 PM
I'm sharing my package for the AutoCAD 2023 network license.
Since version 2023, you need to create your custom installation from your Autodesk account.
:!: In my case, I created a custom image to install, not to deploy from a deployment image :!:
Once the AutoCAD2023.exe file has been downloaded and run, cancel the installation on the dev machine and retrieve the image folder in c:\Autodesk\{GUID} to copy it to the root of the package.
:!: It is crucial not to modify the user registry before the software is run for the first time; hence the use of the audit function to disable telemetry :!:
:!: The run command of the uninstall function should accept error code 1603 due to an uninstallable patch: https://learn.microsoft.com/en-us/windo ... le-patches :!:
control file:
depends           : wapt-vcredist2012
audit_schedule    : 5
setup.py file:
import platform
try:
    from waptenterprise.waptservice.enterprise import get_active_sessions, start_interactive_process
except:
    from waptservice.enterprise import get_active_sessions, start_interactive_process
    # Installing the software
    install_exe_if_needed('image\Installer.exe',silentflags="-i deploy --offline_mode --ui_mode silent -o image\Collection.xml",key="{423E5E4A-E412-31C8-94B8-7A1171D35541}",min_version=control.get_software_version(),timeout=900)
    uninstallkey.remove('{423E5E4A-E412-31C8-94B8-7A1171D35541}')
    # Uninstalling Autodesk desktop application because update will be manage with wapt
    print('Uninstalling Application de bureau Autodesk')
    killalltasks("AdAppMgr.exe")
    killalltasks("Autodeskdesktopapp.exe")
    service_stop("AdAppMgrSVC")
    remove_tree(r'%s\Autodesk\SDS' % programdata)
    run(r'"%s\Autodesk\Autodesk Desktop App\removeAdAppMgr.exe" --mode unattended' % programfiles32)
def session_setup():
    # Disable telemetry
    if registry_readstring(HKEY_CURRENT_USER,r'SOFTWARE\\Autodesk\\AutoCAD\\R24.2\\ACAD-6101:40C\\InfoCenter','InfoCenterOn'):
        registry_set(HKEY_CURRENT_USER,r'SOFTWARE\\Autodesk\\AutoCAD\\R24.2\\ACAD-6101:40C\\InfoCenter','InfoCenterOn',0,type=REG_DWORD)
def audit():
    run_session_setup(control.package)
    return "OK"
def run_session_setup(package_name):
    for session_id in get_active_sessions():
        start_interactive_process("wapt-get", "--hide session-setup %s -f" % package_name, session_id=session_id)  # , minimize=True
    # Uninstalling the software
    run(r'"%s\Autodesk\AdODIS\V1\Installer.exe" -i uninstall -q --trigger_point system -m C:\ProgramData\Autodesk\ODIS\metadata\{423E5E4A-E412-31C8-94B8-7A1171D35541}\bundleManifest.xml -x C:\ProgramData\Autodesk\ODIS\metadata\{423E5E4A-E412-31C8-94B8-7A1171D35541}\SetupRes\manifest.xsd --extension_manifest C:\ProgramData\Autodesk\ODIS\metadata\{423E5E4A-E412-31C8-94B8-7A1171D35541}\setup_ext.xml --extension_manifest_xsd C:\ProgramData\Autodesk\ODIS\metadata\{423E5E4A-E412-31C8-94B8-7A1171D35541}\SetupRes\manifest_ext.xsd -o C:\ProgramData\Autodesk\ODIS\metadata\{423E5E4A-E412-31C8-94B8-7A1171D35541}\deploymentCollection.xml' % programfiles64,timeout=600,accept_returncodes=[0, 3010, 1603])
    print('Uninstalling AutoCAD Open in Desktop')
    run(r'"MsiExec.exe" /X{2B8E195A-0082-4B8F-9284-0FCCB6017C23} /quiet')
    print('Uninstalling Enregistrement Autodesk sur le Web et au format mobile')
    run(r'"MsiExec.exe" /X{5AB49421-ADA1-4512-9E47-0AE9906F6A28} /quiet')
    print('Uninstalling Autodesk Single Sign On Component')
    run(r'"MsiExec.exe" /X{88003D19-C1C3-402D-A162-42D9B924266C} /passive')
    print('Uninstalling Autodesk Genuine Service')
    run(r'"MsiExec.exe" /X{F8C64551-A826-4185-9699-FAC37661A7EB} /passive')
    print('Uninstalling Autodesk AutoCAD Performance Feedback Tool 1.3.12')
    run(r'"MsiExec.exe" /X{293C8AB2-59FA-4C6E-A707-EE7457D8F567} /passive')
    print('Uninstalling Autodesk Material Library Base Resolution Image Library 2023')
    run(r'"MsiExec.exe" /X{3B564A94-BA47-4E42-ACD6-B5C35291210B} /passive')
    print('Uninstalling Autodesk App Manager')
    run(r'"MsiExec.exe" /X{4EF1F1D4-E74F-45A8-AF89-95907847D484} /quiet')
    print('Uninstalling Autodesk Material Library 2023')
    run(r'"MsiExec.exe" /X{8E133591-B0FD-4DB0-B60E-FB593CAF72B0} /passive')
    print('Uninstalling Autodesk Applications recommandées Autodesk')
    run(r'"MsiExec.exe" /X{DE8DA5A8-C311-4F2B-B1C3-27A8BC154154} /quiet')
    print('Uninstalling Microsoft .NET Core Runtime - 3.1.10 (x64)')
    run(r'"C:\ProgramData\Package Cache\{4714dd0a-ebab-4f59-a708-f8d7a793b3f5}\dotnet-runtime-3.1.10-win-x64.exe" /uninstall /q')
    print('Uninstalling Microsoft ASP.NET Core 3.1.10 Shared Framework (x64)')
    run(r'"C:\ProgramData\Package Cache\{6efe3294-03d8-4977-9c67-9f57ab075130}\AspNetCoreSharedFrameworkBundle-x64.exe" /uninstall /q')
    print('Cleaning leftover folder')
    remove_tree(makepath(programdata,'Autodesk'))
- Installed WAPT version: 2.6.0.16795 Enterprise
- Server OS: Linux / Debian Bookworm
December 7, 2022 - 12:28
Thank you, Olivier!
