I would like to deploy my OS using the serial number and not the MAC address. Is this possible?
I also want to import a certificate before opening a user account in my XML file (AutotoLogon).
Thank you for your answers.
WADS: Deploying an OS
- WAPT Expert
We considered it, we even started writing code for it, but for the moment it's not possiblesylvain.thorez wrote: ↑Dec 8, 2022 - 11:06 AM Hello,
Instead of using XML, you can create a WAPT package which you install at the end using the postconf script in wadssylvain.thorez wrote: ↑Dec 8, 2022 - 11:06 AM I want to import a certificate before opening a user account in my XML file (AutotoLogon)
