[SOLVED] List machines not seen since a certain date
Share your SQL query ideas for reporting in the WAPT Enterprise console here
May 24, 2019 - 12:24
SELECT h.uuid,h.computer_fqdn,install_date::date,version,h.listening_timestamp::timestamp,h.connected_users from hostsoftwares s
left join hosts h on h.uuid=s.host_id
where
 s.key='WAPT_is1'
and
 h.listening_timestamp<'20190115'
Modify h.listening_timestamp<'20190115' for a specific date
Mathieu
Registration: August 18, 2016 - 10:24
December 11, 2022 - 09:13
I wanted to know if this query works correctly for you because for a little while now I have been getting an error during execution.
Query error
Query error
- WAPT 2.2.3.12463 Enterprise
- Debian 9.9
- Windows 10 21H2 & Windows 11 22h2
December 29, 2022 - 5:38 PM
Indeed, it no longer works after an update
listening_timestamp no longer exists, so I used last_seen_on
SELECT h.uuid,h.computer_fqdn,install_date::date,version,h.last_seen_on::timestamp,h.connected_users from hostsoftwares s
where
 s.key='WAPT_is1'
and
 h.last_seen_on<'20230101'
julien.guyonnet
Registration: Apr 21, 2021 - 10:38
January 5, 2023 - 10:36 PM
For a dynamic date 'D - 45 days'
h.last_seen_on<TO_CHAR(CURRENT_DATE - 45, 'yyyymmdd')
Is it possible to use this query to filter the inventory tab?
