[SOLVED] Shortcut creation problem
Clement
Registration: December 20, 2022 - 12:25
December 27, 2022 - 5:52 PM
Installed WAPT version: 2.2.3.12481, Enterprise edition.
Server OS:
Operating system (administrative machine/package creation): Windows 10
(I have put the information specific to my company in brackets.)
I'm having trouble creating a package. I want to create a desktop shortcut that points to our ticketing tool, and for that, I created this Python script:
def session_setup():
    create_user_desktop_shortcut(r'Formulaire-GLPI',target='http://support-informatique[...].fr/')
I don't get an error message when I run "wapt:session-setup" from PyScripter:
Command Line : session-setup "c:\waptdev\[...]-FormulaireGLPI_1_x64_Windows_PROD-wapt\WAPT\.."
Configuring c:\waptdev\[...]-FormulaireGLPI_1_x64_Windows_PROD-wapt ...
Running session_setup for package [...]-FormulaireGLPI(=1-0) and user [...]
Done
But I don't have a shortcut added to my desktop.
My boss ran it on his machine and it works, so it's not the script.
I think it might be due to a config file on my machine but I can't see which one (I've already gone through wapt-get.ini).
I'm afraid I'll be blocked from creating any more packages.
Do you have any idea what could be causing this?
Thank you in advance.
Clement
julien.guyonnet
Registration: Apr 21, 2021 - 10:38
December 27, 2022 - 6:34 PM
I find the behavior of session_setup sometimes difficult to predict.
This is linked to the various launch contexts:
- from Pyscripter (launched with an admin account on the development machine)
- package installation from the wapt console (only one user logged into the machine)
- from the self-service
- during shutdown.
The question I consistently ask myself is, "Which account is it running under?"
December 29, 2022 - 11:54 AM
julien.guyonnet wrote: ↑Dec 27, 2022 - 6:34 PM - from Pyscripter (launched with an admin account on the dev machine)
with the session that launched PyScripter, therefore the admin account
julien.guyonnet wrote: ↑Dec 27, 2022 - 6:34 PM - Package installed from the wapt console (only one user connected to the machine)
The session setup will be launched in all sessions opened with the user's account (this is an impersonation)
julien.guyonnet wrote: ↑Dec 27, 2022 - 6:34 PM - from the self-service area
Same as the previous case (impersonation)
julien.guyonnet wrote: ↑Dec 27, 2022 - 6:34 PM - during the extinction
No session is open at this time, so session setup is not launched. However, since session setup is opened every time a session is opened, it will run at the next session opening
ATTENTION :arrow:
It's important to remember that session setup runs only once per package version and only once per session. Therefore, if you create a shortcut on a user's desktop and they delete it, the next execution of session setup will not recreate the shortcut, as it has already been run in the session for package version 1.0-2.
Clement
January 3, 2023 - 5:50 PM
I created a new script this time for the Office 365 installation:
    if not installed_softwares(u'O365BusinessRetail'):
        print('Microsoft Office 365: Installation en cours...')
        run(u'OfficeSetup.exe /configure ConfigurationOffice365.xml',timeout=2000,accept_returncodes=[1641,3010,0])
        print('Microsoft Office 365: Installation OK')
        print('Microsoft Office 365: Deja installe!')
    if not isdir(makepath(programefiles,'Microsoft Office','OfficeClickToRunWAPTUninstall')):
        mkdirs(makepath(programefiles,'Microsoft Office','OfficeClickToRunWAPTUninstall'))
    filecopyto ('OfficeSetup.exe',makepath(programfiles,'Microsoft Office','OfficeClickToRunWAPTUninstall','ConfigurationUninstall.xml'))
    print('Microsoft Office 365: Desinstallation...')
    #Closing applications:
    killalltasks(['WINWORD.EXE','POWERPNT.EXE','EXCEL.EXE','MSPUB.EXE','MSACCESS.EXE','ONEDRIVE.EXE','OUTLOOK.EXE','ONENOTE.EXE','Teams.exe'])
    #Uninstalling:
    if installed_softwares(u'O365BusinessRetail'):
        if isfile(makepath(programfiles,'Microsoft Office','OfficeClickToRunWAPTUninstall','OfficeSetup.exe')):
            run('"' + makepath(programfiles,'Microsoft Office','OfficeClickToRunWAPTUninstall','OfficeSetup.exe') + r'" /configure UninstallOffice365.xml',timeout=2000,accept_returncodes=[1641,3010,0])
            remove_file(makepath(programfiles,'Microsoft Office','OfficeClickToRunWAPTUninstall','OfficeSetup.exe'))
            remove_file(makepath(programfiles,'Microsoft Office','OfficeClickToRunWAPTUninstall','UninstallOffice365.xml'))
            if dir_is_empty(makepath(programfiles,'Microsoft Office','OfficeClickToRunWAPTUninstall')):
                remove_tree(makepath(programfiles,'Microsoft Office','OfficeClickToRunWAPTUninstall'))
    print('Microsoft Office 365: Desinstallation terminee')
Same as before: no error message, but not the expected result either:
Command Line : install "c:\waptdev\[...]-microsoft-office_16.0.15225.20288_x64_Windows_PROD\WAPT\.."
Installing WAPT files c:\waptdev\[...]-microsoft-office_16.0.15225.20288_x64_Windows_PROD
Installing: OfficeSetup.exe
Installing: OfficeSetup.exe (16.0.15225.20288)
Results :
 === install packages ===
  c:\waptdev\[...]-microsoft-office_16.0.15225.20288_x64_Windows_PROD | [...]-microsoft-office (16.0.15225.20288-0)
Since I already have Office installed on my computer, I should at least have received the message "Microsoft Office 365: Already installed!" but nothing happens.
Any ideas?
Clement
January 4, 2023 - 12:34
Hello Clément,
please do not reuse an existing thread for a new topic. If you have a new question, please start a new thread.
Regards,
