PostgreSQL database error following database migration
Geovariances
Registration: July 28, 2020 - 10:56 AM
January 3, 2023 - 5:58 PM
Hello and Happy New Year to everyone!
I installed a test server (DEBIAN 10) in version 2.2.6.2 and then exported my current database (via the export procedure documented on the site) in 1.8.2.
Once exported, I performed a postconf and a restoration of the database and the necessary directories.
First, my database hasn't been updated to 2.2.6.2. Is postconf supposed to do that?
Second problem: I'm getting an error starting the waptserver service. This error is related to my PostgreSQL database
> Traceback (most recent call last):
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 3144, in execute_sql
    cursor.execute(sql, params or ())
psycopg2.errors.UndefinedColumn: column t1.user_fingerprint does not exist
LINE 1: ...od", "t1"."description", "t1"."user_certificate", "t1"."user...
How to get out of this problem?
It's a test machine but it allows me to validate an upgrade from my 1.8.2 to a 2.2.
Mickaël
January 4, 2023 - 2:20 PM
Which version exactly is it? Wasn't there a version 2.2.6? The error message indicates that the database wasn't upgraded correctly.
The database is updated when the waptserver service starts. However, in older versions, this could happen silently. Could you test the latest version, 2.2.3.12485? The service startup should fail if the database upgrade doesn't go through.
Afterward, you should post the error logs here.
Denis Cardon
Geovariances
January 4, 2023 - 5:31 PM
the WaptServer version is 2.2.3.12485 to be precise.
I'll look into upgrading it and post the logs tomorrow.
Thanks
, Mickaël
January 5, 2023 - 12:08 PM
if you were already on version 2.2.3.12485, it's strange that it's crashing. Were you on the latest version, 1.8.2.7393, before upgrading?
Regards,
Geovariances
January 9, 2023 - 11:01
dcardon wrote: January 5, 2023 - 12:08 PM Hello,
Regards,
No, version 1.8.2.7334 is the version of the server to be upgraded.
