[RESOLVED] Version 2.3: First bug: no packages visible in a target's configuration
t.heroult
Registration: December 8, 2020 - 10:13 AM
January 10, 2023 - 3:06 PM
I updated the WAPT server to version 2.3.
When I go to the configuration of a machine (with the new agent or the old one, it's the same), the list of available packages only contains packages created after the server update!
In the repository, all the packages are still present, but it is now impossible to add one to a target.
Server: WAPT Enterprise 2.6.1.17786 on Debian
Consoles: Windows 10 & 11
Infrastructure: Windows
Littlebox
Registration: Oct 21, 2020 - 4:55 p.m.
January 10, 2023 - 3:55 PM
I had the same issue; by re-signing the packages, it was possible to assign them to the hosts again.
January 10, 2023 - 3:59 PM
During the database upgrade, the table of available packages is recreated (because in some installations, package UUIDs were duplicated)
but it is not re-populated with the contents of the packages.
You can do this with the command:
(debian)
wapt-scanpackages -b /var/www/wapt
t.heroult
January 10, 2023 - 4:26 PM
The command works fine, everything is OK :)
. Thank you!
