I just created an Active Directory group with a machine included, as explained here: https://www.wapt.fr/fr/doc/wapt-console ... se-feature.
I used the same name in lowercase in both AD and WPT AD Profile. The WPT agent is correctly configured with `use_ad_groups=1`.
I'm finding that the deployment isn't working!
I'd like more information: is it possible to do this with groups that include users instead of machines?
Thank you for your prompt reply.
[RESOLVED] WAPT + AD GROUP
- WAPT Expert
there are a few nuances here:
[*]The PC must be a direct member of the group (not a nested group).
[*]The group cache is refreshed every 2 hours, so if you just made the change, you can force a cache refresh from the console using "Force GPO update on machine."
[*]It is strongly recommended that the group name and the WAPT package name "AD profile" be entirely in lowercase and without spaces or special characters. We have already had some issues with this.
Could you please check these points?
- WAPT Expert
In the absence of a response, I'm marking this topic as resolved.
Regards,
Regards,
