[SOLVED] Difficulties with the vcredist/openoffice package
Duster
Registration: January 19, 2022 - 12:20
January 18, 2023 - 08:49
Hello everyone,
I'd like to ask for the community's help with a small package issue. We've been using WAPT for about a year in a fairly "simple" way, meaning without much advanced configuration, and I'm encountering a small problem when updating OpenOffice.
I've successfully deployed the OpenOffice package, its dependency tis-vcredist, and its dependency tis-vcredist2015-2022 to the test machine.
The problem is that for some time now, the vcredist2015-2022 package has consistently thrown an error, which disrupts the installation of the other two packages (OpenOffice and vcredist).
Here is the error message in detail:
Installing: VC_redist.x64.exe
File "C:\Program Files (x86)\wapt\common.py", line 4063, in install_wapt
File "C:\Windows\TEMP\waptya_ybbdl\setup.py", line 37, in install
File "C:\Program Files (x86)\wapt\common.py", line 3840, in run
File "C:\Program Files (x86)\wapt\waptutils.py", line 2138, in run
waptutils.CalledProcessErrorOutput: Command '"VC_redist.x64.exe" /quiet /norestart' returned non-zero exit status 1.
Output: '"VC_redist.x64.exe"' is not recognized as an internal
or external command, operable program or batch file.
Information about our setup:
WAPT Enterprise installed on Windows
version 2.3.0.13356.
Thank you in advance for any help you can provide.
January 18, 2023 - 6:13 PM
Hi Arnaud,
it seems that the VC_redist.x64.exe file (which is in the wapt package) is missing after unzipping the package.
* Can you verify that it's still in the package on your server? What is the size of your package? If the package is too small, could you have run a local package update that crashed?
* Otherwise, it could be your antivirus deleting it randomly, but that would be strange for a file signed by Microsoft...
Best regards,
Duster
January 19, 2023 - 09:23
Hello dcardon!
Thank you for your response.
* Can you verify that it's indeed in the package on your server? What is the size of your package? If the package is too small, could you have accidentally run a local package update that crashed?
I think that was it! Following your message, I saw that the package was only 7KB. The simple workaround I used was to remove the two packages (tis-vcredist and its dependency tis-vcredist2015-2022) from my repository. Then, when I re-imported them, everything was resolved and it seems to be deploying correctly on my test machine.
Thanks again, it's resolved!
January 19, 2023 - 5:28 PM
Great, :-) thanks for your feedback,
