[SOLVED] Problem after updating to 2.3.0
guigeek
Registration: Nov 21, 2017 - 9:21 p.m.
January 25, 2023 - 09:20
Hello everyone!
After updating to version 2.3.0, I'm having problems when changing maturity levels, for example, with the following errors:
CRITICAL Error uploading package ... Package filename / name is forbidden
CRITICAL merge_stripped_package failed EWaptForbiddden('Package filename / name is forbidden
Any idea what the problem is?
THANKS!
January 25, 2023 - 10:08
Hello Guillaume,
guigeek wrote: ↑Jan 25, 2023 - 09:20 CRITICAL merge_stripped_package failed EWaptForbiddden('Package filename / name is forbidden
What is the name of the package?
guigeek
January 25, 2023 - 12:51
I have the problem with waptupgrade for example:
;Package;Version;Maturity;Status;Message
;stm-waptupgrade;2.3.0.13438-43;PROD;ERROR;Upload error for stm-waptupgrade_2.3.0.13438-43_Change maturity to DEV_33995ddb-86fd-4a67-be97-16bbd7900019: Error on server:
EWaptForbiddden('Package filename / name is forbidden: stm-waptupgrade_2.3.0.13438-43_all_Change maturity to DEV_all_336e4baee8e892aa9725b8c0470b1fb6.wapt')
January 25, 2023 - 2:28 PM
Oops, there's a usability issue. In the maturity change window, you must select a maturity level from the combo box at the top; otherwise, the text "change maturity to" is selected.
This will be fixed in the next version. That said, it's important to choose the correct package maturity.
Regards,
guigeek
January 25, 2023 - 2:35 PM
Ah yes, my bad... weird, I don't think I did it before. I think production was selected by default when I changed the maturity level of a development package...
Or maybe I'm not fully awake yet... quite possible :lol:
. Thanks a lot!
guigeek
January 25, 2023 - 2:38 PM
Oh no, I'm not crazy! ;)
I tried again with WaptUpgrade... if I switch from production to development... development is pre-selected, but I get an error. However, if I activate the maturity combobox to choose development, it works!
Thanks!
January 25, 2023 - 5:18 PM
This will be fixed in the next release. Thank you for reporting the bug. I'm marking this topic as resolved.
Regards,
