Bug update from version 2.3 to 2.3.0.13438
Greg
Registration: January 24, 2023 - 3:22 PM
January 24, 2023 - 3:49 PM
Hello, I'm having several problems with my WAPT server.
OS: Debian 11 Bullseye
Version: 2.3.0
Discovery version (after trying an enterprise license)
Console OS: Windows Server 2019
Console version: 2.3.0.13438
I upgraded from 2.3 to 2.3.13438 (modifying the apt file).
All packages have upgraded correctly according to dpkg, although the "debian-10" in the waptsetup file leaves me with some doubt:
ii tis-waptserver 2.3.0.13438-8e580896-debian-11-amd64 amd64 WAPT Server for machines software management.
ii tis-waptsetup 2.3.0.13438-8e580896-debian-10-amd64 all WAPT setup executable for Windows.
However, when I access the web interface of the server, I'm still on version 2.3.0:
WAPT Server Version: 2.3.0
WAPT Agent
Version: 2.3.0.13438 WAPT Setup Version: 2.3.0.13438
WAPT Deploy Version: 2.3.0.13438.
I tried `apt --reinstall`, but it didn't help.
In the console, I have another problem in the "Download and send agent installers" section. I get two "Package missing" errors for waptdeploy.exe and waptsetup.exe. If I delete the waptsetup agent and rebuild it, I get the error "Windows waptupgrade not yet supported". For waptdeploy, if I delete it, it disappears from the list and I have to download it (from Tranquil IT) and manually add it back to /var/www/wapt/waptagent/.
The last problem (which I think is related) is that I can no longer deploy the agent with waptdeploy via GPO.
Manually, the client retrieves the agent correctly, but then I get an "Unable to read file version" error. I have to use the --force option to deploy the agent on the client, and this would cause a problem if I included the option in the GPO script.
That's it. I hope I haven't forgotten anything and that I've been clear enough. If anyone has encountered this problem before, I'd be very grateful for any advice.
Thanks in advance
January 25, 2023 - 6:11 PM
Good morning
Greg wrote: Jan 24, 2023 - 3:49 PM Hello, I have several problems on my WAPT server.
Version: 2.3.0
I upgraded from 2.3 to 2.3.13438 (modified the apt file).
All packages upgraded correctly according to dpkg, although the "debian-10" in the waptsetup file leaves me with some doubt:
Or when I go to the web part of the server I am still on 2.3.0:
WAPT Server version: 2.3.0
WAPT Agent version: 2.3.0.13438
WAPT Setup version: 2.3.0.13438
WAPT Deploy version: 2.3.0.13438
I tried an apt --reinstall but nothing works.
Actually, that's normal; it's just that the web interface wasn't displaying the full version. I've just fixed that to avoid any confusion
Greg wrote: Jan 24, 2023 - 3:49 PM In the console, I have another problem in the "Download and send agent installers" section. I get two "Package missing" errors for waptdeploy.exe and waptsetup.exe. If I delete the waptsetup agent and rebuild it, I get the error "Windows waptupgrade not yet supported". For waptdeploy, if I delete it, it disappears from the list and I have to download it (from Tranquil IT) and manually add it back to /var/www/wapt/waptagent/.
Normally the "Download and send agent installers" section was not originally intended to manage Windows since you have it in the menu.
"Tools" generates a WAPT agent which is used to generate Windows. We need to do something to make the GUI clearer. We'll remove "Windows" from the list to avoid confusion.
Greg wrote: Jan 24, 2023 - 3:49 PM Last problem (related, I think): I can no longer deploy the agent with waptdeploy via GPO.
That's it. I hope I haven't forgotten anything and that I've been clear enough. If anyone has encountered this problem before, I'd be very grateful for any help.
Thanks in advance
Regarding this last issue, we do indeed have a problem in the latest version; we will release a new one soon. In the meantime, you can use the waptdeploy from an older version of wapt.
Greg
January 26, 2023 - 09:46
Thanks for your replies!
I'll change waptdeploy in that case and ignore the rest
. Have a good day!
