[RESOLVED] Wake On LAN not working
Patrice
Registration: February 18, 2015 - 3:22 PM
February 6, 2023 - 2:36 PM
Hello everyone,
We are currently using WAPT Enterprise 2.2.3.12463 and when we try to start the powered-off workstations in our organization with the command "Getting Started with Wake On LANThe following error message is displayed:
Erreur lors de l'envoi des paquets WakeOnLan aux hôtes relais
For clarification, the Wake On Lan function in the BIOS of the test machines is indeed enabled.
What is meant by relay hosts? Is it necessary to configure the wapt-get.ini file to do this?
Thank you for your help.
Patrice
WAPT Enterprise 2.2
February 9, 2023 - 11:10
Hello Patrice,
this bug has been fixed in the latest version 2.2.3 (see changelog https://www.wapt.fr/en/doc-2.2/wapt-cha ... 2022-11-30). You can upgrade to this version or to version 2.3.
Regards,
