[SOLVED] Stormshield SSLVPN Client Package v3.2.1
olaplanche
Registration: January 26, 2017 - 11:11
November 28, 2022 - 2:35 PM
The problem present in previous versions has been fixed in the latest version; system account installation finally works correctly!
# Defining variables
bin_name_string = 'Stormshield_SSLVPN_Client_%s_win10_fr_x64.msi'
vpn_server = 'xxx.yyy.zzz' # Set default vpn server fqdn to connect to
    # Initializing variables
    bin_name = bin_name_string % package_version
    # Installing the package
    print('Installing %s' % bin_name)
    install_msi_if_needed(bin_name)
    killalltasks(control.impacted_process.split(",")) # Kill client process launched with system account
    create_programs_menu_shortcut('Stormshield SSL VPN Client','C:\Program Files\Stormshield\Stormshield SSL VPN Client\sslvpn_client.exe',wDir='C:\Program Files\Stormshield\Stormshield SSL VPN Client\\',folder='Stormshield SSL VPN Client')
def session_setup():
    currentuser = os.getlogin()
    # Configuring user client default vpn server to connect to
    registry_set(HKEY_CURRENT_USER,r'Software\\STORMSHIELD\\STORMSHIELD SSL VPN CLIENT','address',vpn_server,type=REG_SZ)
    registry_set(HKEY_CURRENT_USER,r'Software\\STORMSHIELD\\STORMSHIELD SSL VPN CLIENT','automatic','true',type=REG_SZ)
    registry_set(HKEY_CURRENT_USER,r'Software\\STORMSHIELD\\STORMSHIELD SSL VPN CLIENT','username',currentuser,type=REG_SZ)
    remove_programs_menu_folder('Stormshield SSL VPN Client')
Changelog from 01/02/23:
  • The code has been updated because the uninstallkey changes between each version of the software; the install_msi_if_needed function handles it very well, so we might as well rely on it :D
  • The same applies to impacted_process once it is entered in the "sslvpn_client" control file
- Installed WAPT version: 2.6.0.16795 Enterprise
- Server OS: Linux / Debian Bookworm
realynot
Registration: Oct 09, 2018 - 4:55 p.m.
January 30, 2023 - 12:15
Thank you for the package
I have just adapted it for the latest version 3.2.0 by adding the uninstallation of previous versions.
Everything went perfectly with the WAPT package, uninstalling and installing was OK.
However, at the Stormshield client level, it then gets stuck on
Is it the same where you live?
vpn_server = 'xx.xxx.fr' # Set default vpn server fqdn to connect to
  for soft in installed_softwares('Stormshield SSL VPN Client'):
    if Version(soft['version']) < Version('3.2.0'):
    impacted_process = control.impacted_process.split(",")
    install_msi_if_needed(bin_name,killbefore=impacted_process)
    uninstallkey.remove('{A74BDC23-D51E-4EB2-9175-F1EC67EC37F0}')
    killalltasks('sslvpn_client.exe') # Kill client process launched with system account
    run('msiexec.exe /x "{A74BDC23-D51E-4EB2-9175-F1EC67EC37F0}" /qn')
olaplanche
February 1, 2023 - 9:55 AM
I just updated my package and code because the uninstall key changes between each version of the software.
I had unnecessarily complicated things. I tested the installation, uninstallation, and update. Everything works on my test machine.
No issues with the local service.
Didier
Registration: August 11, 2015 - 4:52 PM
February 7, 2023 - 3:38 PM
Hello and thank you! I happily used your codes :mrgreen:
I have the same problem as you @realynot, ("please wait while local service is being processed"...)
Were you able to get around the problem?
Alternatively, I added the option to launch it at client startup for all users:
vpn_server = 'vpn.xxxxxxx.xx' # Set default vpn server fqdn to connect to
    registry_set(HKEY_LOCAL_MACHINE,makepath('SOFTWARE','Microsoft','Windows','CurrentVersion','Run'),'stormshield-vpn','C:\Program Files\Stormshield\Stormshield SSL VPN Client\sslvpn_client.exe',type=REG_SZ)
    if reg_key_exists(HKEY_LOCAL_MACHINE,r'Software\Microsoft\Windows\CurrentVersion\run\stormshield-vpn'):
        run('reg delete "Software\Microsoft\Windows\CurrentVersion\run\stormshield-vpn" /f')
olaplanche
February 8, 2023 - 8:45 AM
is the local service "StormshieldSSLVPNService" properly started under the local system account?
jdziadek
Registration: January 23, 2023 - 4:10 PM
February 15, 2023 - 09:49
olaplanche wrote: ↑Feb 8, 2023 - 08:45 Hello,
Is the local service "StormshieldSSLVPNService" properly started under the local system account?
Hello, I have the same problem here, and the service is definitely started under the local system account
Debian 11
WAPT Version: 2.4.0.14143
olaplanche
February 15, 2023 - 11:01
And is the virtual network adapter correctly created in the Windows network adapters?
jdziadek
February 16, 2023 - 09:01
olaplanche wrote: ↑Feb 15, 2023 - 11:01 And is the virtual network adapter properly created in the Windows network adapters?
Yes, everything is OK at that level as well. The update on a machine that already had the client installed works without any problems, but a fresh install does not
Debian 11
olaplanche
February 17, 2023 - 09:41
I just tested again on my dev VM and I can't reproduce your problem. Everything is fine on my end...
I also tested on my production machine, no issues.
For your information: both machines are running Windows 10 21H2 (haven't tested on Windows 11).
Could someone try manually uninstalling the VPN client (appwiz.cpl) and reinstalling it via Wapt?
Thanks
jdziadek
February 17, 2023 - 10:00
olaplanche wrote: ↑Feb 17, 2023 - 9:41 AM I just tested again on my dev VM and I can't reproduce your problem. Everything is OK on my end...
For your information: both machines are running Windows 10 21H2 (not tested on Windows 11).
Could someone try manually uninstalling the VPN client (appwiz.cpl) and reinstalling it via wapt?
Thanks
Hello, the problem we're also encountering is that it doesn't appear in appwiz.cpl
Debian 11
