we need the package error.
Click on your machine in the console, then on the package with the error.
You'll see the error message right below.
- Simon
setup.py script template
- WAPT Expert
I'm getting this message on the console:
I have nothing else
Installing test-nuxeobrowser
Exception: Error during install of test-nuxeobrowser (=2.1.3-7): errors in packages test-nuxeobrowser
File "C:\wapt\waptservice\waptservice.py", line 2063, in run
self.running_task.run()
File "C:\wapt\waptservice\waptservice.py", line 1323, in pwrapper
return func(*arg, **kwargs)
File "C:\wapt\waptservice\waptservice.py", line 1383, in run
self._run()
File "C:\wapt\waptservice\waptservice.py", line 1807, in _run
','.join([ p[1].package for p in self.result['errors']]),
I have nothing else
I hadn't seen this message
EWaptSetupException: Fatal error : msi file Nuxeo-MSIEBrowserExtension.msi /quiet /norestart not found in packageNow I'm getting this error:
I've had it up to here !!
CalledProcessError: Command '('msiexec /norestart /q /i "Nuxeo-MSIEBrowserExtension.msi" ',)' returned non-zero exit status 1612- sfonteneau
- WAPT Expert
The error codes are Windows errors:
MSI Error 1612: 'Installation source for this product is not available'
The error message indicates that the installation source for this product is not available.
Without using Wapt, have you tried launching it from the command line?
Does the MSI work well when launched manually?
msiexec /norestart /q /i "Nuxeo-MSIEBrowserExtension.msi"Simon
Yes, by launching this command It works, the installation goes smoothly in silent mode!
msiexec /norestart /q /i "Nuxeo-MSIEBrowserExtension.msi"- sfonteneau
- WAPT Expert
It is possible that your installation does not allow installation in system account:
On your administrator machine, can you run the following command:
If the installation works, you have the explanation
wapt-get install --direct test-nuxeobrowserSimon
if iswin64():
install_msi_if_needed('PXCViewer_x64.msi',key='PDF-XChange Viewer',silentflags='/quiet /norestart KEY="XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX" USERNAME="XXX" ORGANIZATION="XXX"',min_version='2.5.205.0',killbefore=['PDFXCview.exe'], accept_returncodes=[0, 1602, 1615, 1603], timeout=300)
install_msi_if_needed('PXCViewer_x86.msi',key='PDF-XChange Viewer',silentflags='/quiet /norestart KEY="XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX" USERNAME="XXX" ORGANIZATION="XXX"',min_version='2.5.205.0',killbefore=['PDFXCview.exe'], accept_returncodes=[0, 1602, 1615, 1603], timeout=300)- sfonteneau
- WAPT Expert
Good morning
Yes, it's possible:
https://github.com/tranquilit/WAPT/blob ... s.py#L3323
But it's not "silentflag", it's "properties" (see the function in the setuphelper above)
But the basic arguments for making the MSI silent have already been covered:
https://github.com/tranquilit/WAPT/blob ... s.py#L3363
For LibreOffice, for example:
Yes, it's possible:
install_msi_if_needed(msi,killbefore=['soffice.bin'],timeout=1200,properties='SELECT_WORD':1,'SELECT_EXCEL':1,'SELECT_POWERPOINT':1,'CREATEDESKTOPLINK':0,'RebootYesNo':'No','ALLUSER':1,'ISCHECKFORPRODUCTUPDATES':0,'QUICKSTART':0)
