[RESOLVED] Updating the "DN in AD" field following a domain change.
croquebert
Registration: March 30, 2022 - 5:41 PM
February 21, 2023 - 3:28 PM
Hello everyone,
Context:
WAPT version: 2.2 Enterprise
Server OS: Debian 11
Administration console OS: Win10pro
Package development workstation OS: Win10pro
We have migrated workstations with the WAPT agent to a new Active Directory domain.
In the WAPT console, the domain controller field updates correctly and points to the domain controller of the new domain.
However, despite restarting the WAPT agent on the client, the "DN in AD" field still points to the DN of the old domain controller: consequently, the PC does not appear in the hierarchy of the new domain controller and cannot correctly apply OU packages.
How can I force the "DN in AD" field to update?
Best regards,
Christophe.
February 21, 2023 - 6:21 PM
You can force an inventory update in the console using the
"Refresh workstation inventory"
from the context menu of all workstations.
You must select the workstations you want to update. Only connected workstations will receive the command.
croquebert
February 23, 2023 - 1:37 PM
htouvet wrote: ↑Feb 21, 2023 - 6:21 PM You can force an inventory update in the console using the
You must select the workstations in question. Only connected workstations will receive the command.
Thank you for your feedback.
Despite restarting the workstation and refreshing the workstation inventory in the console, the "DN in AD" field still points to the DN of the old domain controller.
Do you have the command used by the WAPT inventory to retrieve this DN in order to verify what it returns live on the workstation?
February 23, 2023 - 3:29 PM
Good morning
The information can be retrieved here:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Group Policy\State\Machine\Distinguished-Name
Therefore, it is directly retrieved by the GPO engine of your computer
croquebert
February 23, 2023 - 7:17 PM
sfonteneau wrote: ↑Feb 23, 2023 - 3:29 PM Good morning
Therefore, it directly retrieves data from the GPO engine of your computer
OK, thank you. I'll look into why this field isn't updating on the client side.
