I'm creating this new topic because I haven't found an answer in the other sections.
Here's the problem:
I want to deploy the workstation inventory using the WAPT agent and GLPI 9.
This morning, I installed version 2.3 (previously 2.2) on the Windows server
, following the documentation: https://www.wapt.fr/fr/doc/wapt-console ... -glpi.html.
It states that the agent is installed by default with WAPTServer (meaning the server will handle sending information to GLPI on our end).
However, the agent isn't installed.
If I perform a standard agent installation, as I did for our workstations, the installation is done under C:\Program Files... and the server appears correctly in the console. I can therefore deploy the GLPI-9x package.
The problem is... the server component is installed on the server's D:\ drive.
When I run a command-line audit: `wapt-get audit tis-glpi....`, it tells me that no package is installed. This is normal because the file used for this command is `wapt-get.ini` located on the D:\ drive, not the one on C:\Program Files....
So I'm stuck, unable to deploy the package but unable to run the audit to verify it's working.
Do you have any idea how to fix this problem? Should I install the agent on D:\, risking overwriting server configuration files?
Thanks in advance for your help!
