[SOLVED] tis-dotnetfx3.5 problem
Zanef57
Registration: February 21, 2023 - 3:50 PM
February 21, 2023 - 4:10 PM
We are on version 2.3 of WAPT Discovery.
We have been experiencing an installation problem with the tis-dotnetfx3.5 package on Windows 11 PCs since 22H2.
I saw that in setup.py, the command looks for the Windows version to install .NET 3.5
if windows_version() >= Version("10.0.22000"):  # Window 11 version 21H2 and newer
        with EnsureWUAUServRunning():
            if iswin64():
                run(
                    r'dism.exe /Online /Enable-Feature /FeatureName:NetFx3 /Source:"%s" /All /LimitAccess /quiet /norestart'
                    % makepath(basedir, "netfx3-w11v21h2x64")
It's searching for Version("10.0.22000"), whereas in 22h2 on Windows 11 it's .22621?
Or is it the "netfx3-w11v21h2x64" package that is not valid for this version?
Here is the error message:
Ensure wuauserv Auto Update option is disabled
re-enabling wuauserv previous state: 0
  File "C:\Program Files (x86)\wapt\common.py", line 4074, in install_wapt
  File "C:\WINDOWS\TEMP\waptk7tydc7z\setup.py", line 23, in install
  File "C:\Program Files (x86)\wapt\common.py", line 3851, in run
  File "C:\Program Files (x86)\wapt\waptutils.py", line 2112, in run
waptutils.CalledProcessErrorOutput: Command 'dism.exe /Online /Enable-Feature /FeatureName:NetFx3 /Source:"C:\\WINDOWS\\TEMP\\waptk7tydc7z\\netfx3-w11v21h2x64" /All /LimitAccess /quiet /norestart' returned non-zero exit status 2148468767.
Output:
Erreur : 0x800f081f
Impossible de trouver les fichiers sources.
Utilisez l'option « Source » pour indiquer l'emplacement des fichiers requis pour restaurer la fonctionnalité. Pour plus d'informations sur la spécification d'un emplacement source, voir https://go.microsoft.com/fwlink/?LinkId=243077.
Output:
Erreur : 0x800f081f
Thank you in advance for your answers.
jpele
Registration: March 4, 2019 - 12:01
February 22, 2023 - 11:47
You can download the ISO containing the feature on the MVLS platform or equivalent. The ISO is named: "SW_DVD9_Win_11_22H2_x64_MultiLang_LangPackAll_LIP_LoF_X23-12645.ISO". You can then integrate the dependency into the package.
For your information, dotnetfx35 has been EOL since January 12, 2016.
I'm noting a non-priority ticket on our end to add compatibility to Windows 11 v22h2. Thank you for your feedback.
Best regards,
Jimmy
February 24, 2023 - 2:30 PM
Hi Jeremy,
basically, if you're in a hurry, you can update the package for the Win11 22H2 version using the installer Jimmy pointed out.
Otherwise, internally, we'll add a `max_os_version` to the package to exclude installations on Win11 22H2, and then you'll need to create the corresponding new package.
If you're in a hurry and have a support ticket for package creation, you can call your contact at Tranquil IT.
I'll create an internal ticket and mark the topic as resolved in the meantime.
Regards,
Zanef57
March 2, 2023 - 10:57
I successfully downloaded an ISO "SW_DVD9_WIN_PRO_11_22H2.5_64BIT_FRENCH_PRO_ENT_EDU_N_MLF_X23-37772.iso" from the Microsoft website.
In the Source\sxs folder, I copied the file "microsoft-windows-netfx3-ondemand-package~31bf3856ad364e35~amd64~~.cab".
I modified the setup.py file by adding this line:
if windows_version() >= Version("10.0.22621"):  # Window 11 version 22H2 and newer
            if iswin64():
                run(
                    % makepath(basedir, "netfx3-w11v22h2x64")
Everything works perfectly.
Thank you for your answers.
jpele
March 2, 2023 - 12:40
Thank you for your feedback, I didn't think Microsoft was still including the dotnet35 offline installer in its ISOs. 😄
jpele
May 17, 2023 - 12:30
FYI the package has been updated accordingly (https://wapt.tranquil.it/wapt-testing/t ... EPROD.wapt)
