[RESOLVED] Information about WAPT.xxx
t.heroult
Registration: December 8, 2020 - 10:13 AM
February 21, 2023 - 2:12 PM
where can I find an index of WAPT.xxx functions for Python code?
Regards,
Tom
Consoles: Windows 10 & 11
Infrastructure: Windows
February 21, 2023 - 6:44 PM
There is no "official" documentation because these are internal functions of the wapt agent.
However, WAPT is an instance of the Python class "Wapt" which you can find in the "common.py" module in the C:\Program Files (x86)\wapt directory
Search for "class Wapt(BaseObjectClass):"
Some functions are documented in the code.
To test "live" in a PyScripter Python shell:
On a test machine, install and launch PyScripter (the version provided for package development)
In the Python shell at the bottom, type:
from common import *
WAPT = Wapt()
Then you can test the commands.
For example :
WAPT.installed()
WAPT.update()
WAPT.update_server_status()
WAPT.install('unpaquet')
WAPT.remove('unpaquet')
WAPT.audit('unpaquet')
WAPT.forget_packages(['unpaquet','unautrepaquet'])
t.heroult
March 2, 2023 - 2:19 PM
Thanks for the info :)
