[SOLVED] wapt agent and repo_rules
jdziadek
Registration: January 23, 2023 - 4:10 PM
March 7, 2023 - 09:37
Hello, I have a similar problem. All the packages I updated after declaring the repository are not synchronizing.
When I look at the logs:
Exception: Downloaded file https://xxxxxx/wapt/Packages sha256 xxxxxx does not match expected yyyyyy
Debian 11
WAPT Version: 2.4.0.14143
guigeek
Registration: Nov 21, 2017 - 9:21 p.m.
March 8, 2023 - 11:28
I solved my problem.
In fact, in the file /opt/wapt/wapt-get.ini I modified the path: local_repo_path=/home/wapt
and therefore in nginx I had to change the configuration so that nginx points to the local_repo_path.
March 8, 2023 - 12:14
Indeed, if you modify the path, you must update it on the nginx system.
Thanks Guillaume for your feedback, :-)
x-davidl
Registration: Apr 25, 2022 - 5:07 p.m.
March 8, 2023 - 2:46 PM
For jdziadek, it looks like the sync.json file doesn't seem to be the same between the source repository and the mirror machine.
Regards
jdziadek
March 10, 2023 - 08:33
x-davidl wrote: ↑March 8, 2023 - 2:46 PM for jdziadek, it looks like the sync.json file doesn't seem to be the same between the source repository and the mirror machine.
Regards
Hello, my server-side json.sync is indeed old; it lists old packages and not new ones, so it makes sense that it's failing. How can I regenerate it properly?
Julian
Debian 11
