I am looking to create a query that will quickly extract the free space from each machine in my fleet.
For this, there's the Freespace attribute available, which I'm trying to bring up, but it's not working:
select host_metrics->'local_drives'->>'C'->>>'FreeSpace' as "Free Space", host_metrics->'last_logged_on_user' as User, host_info->'computer_fqdn' as Name from hosts
And here's the error it's showing me
I'm not an SQL expert at all; the last time I did it was in class about 15 years ago! It seems to be a formatting issue, if I understand correctly, but I'm a bit stuck. If anyone has any ideas...
Mathieu
[SOLVED] Free disk space per machine
- WAPT Expert
Good evening Mathieu,
You weren't far off. But it's true that PostgreSQL's JSON query syntax isn't the most intuitive.
I added a conversion to GB and rounding to two decimal places.
Denisselect
round(((host_metrics->'local_drives'->'C'->'FreeSpace')::float / 1073741824)::numeric,2) as free_space_en_go ,
os_name,
os_version ,
host_info->'computer_fqdn' as fqdn
from hosts
order by computer_name
- WAPT Expert
Thank you so much to you and the metropolitan area for switching to the Enterprise version. This allows us to properly fund WAPT's development and take WAPT further, and there's still a long way to go
See you soon,
See you soon,
- WAPT Expert
Hello Jérôme,
please do not revive a topic marked as RESOLVED, as this makes forum moderation a bit complicated.
You can start a new topic and reference the existing one. It might also be helpful to specify the version of Wapt you are using.
Regards,
Regards,
