Hello.
I'm currently testing the deployment of WADS OS to replace our MDT (deployed with ipxe on Linux).
However, I'm encountering an issue loading the ipxe script.
The URL http://MYSERVER/api/v3/baseipxe?keymap=fr
returns a 403 error with the following JSON content:
{"success":false,"msg":"forbidden","error_code":""}
WAPT Enterprise Server 2.3.0.13516, running on Linux (Debian Bullseye)
[RESOLVED] OS Deployment: Error 403 loading iPXE script
- WAPT Expert
Have you restarted the postconf?
We've added a question to the postconf asking if you want to enable WADs. If the answer is no, then the response is a 403.
arnaud.houdelette
- Registration: Oct 02, 2019 - 11:24
Indeed. I didn't remember answering that question.
It works now.
Thank you
It works now.
Thank you
- WAPT Expert
Thanks Arnaud for the feedback.
Good luck with the deployment!
